Author Topic: Bags Away!  (Read 25124 times)
Re: Bags Away!
« Reply #60 on: April 15, 2013, 04:59:54 PM »
I just use a zip tie, cheap insurance as my bags are always on.  Good luck.
Re: Bags Away!
« Reply #61 on: April 15, 2013, 07:52:57 PM »
You should post a photo of that method (where it is used) since I don't remember seeing how it is done.
Offline SimpleSimon
2008 Concours 14
2002 954RR
Re: Bags Away!
« Reply #63 on: April 15, 2013, 10:05:36 PM »
I will not be drilling into my bike, so I will be giving the brackets a try.
Re: Bags Away!
« Reply #64 on: April 16, 2013, 04:06:16 AM »
The wire brackets, which I use, are very secure indeed.  Wouldn't help much if someone removes the lock cylinder, though, but then nothing would short of using Brian's anchor chain.
Re: Bags Away!
« Reply #65 on: April 16, 2013, 05:35:58 AM »
+1.  That is why I used the brackets.
Re: Bags Away!
« Reply #66 on: April 16, 2013, 08:13:01 AM »
Max, I just run the zip tie between the latch and the hand rails.  The latch is still functional allowing entry to the bags.
Re: Bags Away!
« Reply #67 on: April 16, 2013, 05:52:38 PM »
Sorry, but no can picture it!!
Offline texrider
Re: Bags Away!
« Reply #68 on: April 16, 2013, 08:16:01 PM »
I used to be one of the I'll never drill guys, then I took the plunge before I lost a bag... 8)
http://www.zggtr.org/index.php?topic=6903.0
2014 Valkyrie
Re: Bags Away!
« Reply #69 on: April 17, 2013, 04:09:03 AM »
Look at texriders thread, reply 1.
Re: Bags Away!
« Reply #70 on: April 17, 2013, 05:30:16 AM »
Cool!  So it goes through the handle then rail.  Simple!
Offline koval68
Re: Bags Away!
« Reply #71 on: April 17, 2013, 08:09:10 AM »
I don't know about you guys, but when I travel, my bags are loaded heavy! With all that weight in the bags, the zip tie will probably break! I don't want to be the one to find out how strong the zip ties are!
I like the way Texrider dealt with this problem, and am taking the same route, before my trip to Colorado.
- Mahatma Gandhi
Re: Bags Away!
« Reply #72 on: April 17, 2013, 08:48:37 AM »
Before I bought Zteve's brackets I used zip ties. I have one break and the bag didn't even have much of a load in it. I didn't lose the bag though.
Offline Barry
Re: Bags Away!
« Reply #73 on: April 17, 2013, 05:29:16 PM »
I am mystified by the " I won't drill my bike " comments.  It's a bracket.  It is a replaceable part.
To me, there is no logic to justify not adding the additional protection of pinning.  Lose a bag, don't lose a bag.  Hmmm... NOT a hard decision.  Cost is under $4.  Too many instances of people losing bags to take no action.
Amazing...  drill away.
Barry
Offline booger
Re: Bags Away!
« Reply #74 on: April 17, 2013, 06:35:13 PM »
Barry
I'm with you Barry.  I just got a long drill bit and drilled away.  I think it looks OK.
Re: Bags Away!
« Reply #75 on: April 17, 2013, 07:14:06 PM »
I pinned my FJR bags, I may pin these at some point but the zip ties I use are pretty strong.  I cannot see the bag breaking them but who knows.  I like the flat black pins.
Re: Bags Away!
« Reply #76 on: April 17, 2013, 07:15:00 PM »
After reading so much about this I decided to make the modification with some clasps that I had on hand;
These arn't going anywhere and look like they came on the bike.
Where did you get the pins?
Re: Bags Away!
« Reply #77 on: April 17, 2013, 09:53:01 PM »
Some of us just don't want to modify our bikes in any permanent way and haven't priced out each part to judge if it is "worth it".  Same way I would NEVER put a bumper sticker on my car, or drill a bike fairing to put in a bracket for a light or some type of mount.  Some people are willing, but only after the bike ages some or reaches some point in time.  Sometimes it is rational, sometimes it is irrational/emotional.
You might not agree with it but it shouldn't be that hard to understand.
Re: Bags Away!
« Reply #78 on: April 17, 2013, 10:42:39 PM »
+1... keep em stock, just like they came from Japan.  ;)
Re: Bags Away!
« Reply #79 on: April 17, 2013, 11:12:11 PM »
No need to pin the bags on the newer ones, they don't come off
