Author Topic: TRANSPONDER FAILURE  (Read 5820 times)
Offline MASIHUNOW
TRANSPONDER FAILURE
« on: June 22, 2013, 06:47:47 PM »
got a low batt message about the transponder this am.  Went back in the house and got the other one, it worked fine.  later picked up a new batt but can not get the bike to recognoze the transponder.  anyone got a clue?
« Last Edit: June 23, 2013, 06:06:49 AM by MASIHUNOW »
Re: TRANSPONDER FAILURE
« Reply #1 on: June 22, 2013, 06:58:53 PM »
Welcome.
First, please put the year of your bike in your signature or avatar text:  http://www.zggtr.org/index.php?topic=8275.0
Next, what has changed recently?  Anything?
Next, it SOUNDS like you have two ACTIVE fobs (implying gen 1), if that is the case, swap batteries in the two and then see what happens.
Offline Scaffolder
« Reply #2 on: June 22, 2013, 09:27:13 PM »
Joel from Maine.
« Reply #3 on: June 23, 2013, 07:15:01 AM »
A brand new battery doesn't mean that it's a good battery. Do you have a multimeter? The new battery should read ~3.2 volts.
« Reply #4 on: June 23, 2013, 07:38:29 AM »
Replace the battery.   Or make sure the polarity is right.
« Reply #5 on: June 23, 2013, 08:24:39 AM »
Hence my suggestion to just swap the batteries :)
« Reply #6 on: June 23, 2013, 08:28:56 AM »
That's too easy and there isn't a cost involved.  It's also logical.  Spock would like it.
« Reply #7 on: June 23, 2013, 08:30:18 AM »
That's a good suggestion but that means he has to open up two fobs. Not that opening up the other fob is a big deal...
If he has a meter he can just test the suspect battery.
« Reply #8 on: June 23, 2013, 10:05:49 AM »
Youse guys gots a one- track mind: 'Replace the battery, replace the battery, replace the battery!'  Didn't you folks learn anything from the recent episode with Burbs?
But in this case, it might be best to replace the battery.  :rotflmao:  But first, check to make sure the battery is put in the right way, and that contacts are all.... contacting and clean.
« Reply #9 on: June 23, 2013, 10:17:55 AM »
No. ;)
Offline PH14
« Reply #10 on: June 23, 2013, 12:56:28 PM »
Or replace the battery and be sure the contacts are clean.  :deadhorse:
 :thumbs:
 :finger_fing11:
« Reply #11 on: June 23, 2013, 02:17:06 PM »
Did you'd guys miss the part where the op said that he replaced the battery?
Offline PH14
« Reply #12 on: June 23, 2013, 02:27:20 PM »
He said he "picked up a new battery" but he never said he actually replaced it. Pay attention.  :doh: ;D
« Reply #13 on: June 23, 2013, 04:35:13 PM »
Yeah, get with the program, Conrad. ;)   Good save, PH14.  You've been promoted.
« Last Edit: June 23, 2013, 05:48:13 PM by VirginiaJim »
« Reply #14 on: June 23, 2013, 04:35:44 PM »
Haven't heard from the op. You guys run another noob off?
« Reply #15 on: June 23, 2013, 04:45:50 PM »
I said "Welcome"!
« Reply #16 on: June 23, 2013, 05:52:43 PM »
I sincerely hope not, Gary.  But that's the way it can be here.  We like to frolic with words and humor.  I know I do.  Nothing mean was said that I can see.  Members make fun of me and I'm still here.. :yikes:   I haven't slain anyone lately either, in fact not in a great while.  Sword's getting a bit rusty I fear.
And......and.....who was the other member we (collectively) ran off?
I said "Welcome"!
Have a cookie. :D
See, I am an equal opportunity poker of fun....
« Reply #17 on: June 23, 2013, 06:18:55 PM »
Meaning....? You will poke anything? Anyone? Please elaborate.  No, no, on second thought keep it to yourself. We don't want to know.  :-X
Remember, one cannot ruin a KiPass thread 'cause they are already sorta' ruined when the title line is typed in.  ;)
« Reply #18 on: June 23, 2013, 06:19:53 PM »
Offline PH14
« Reply #19 on: June 23, 2013, 08:37:13 PM »
 :finger_fing11: :chugbeer:
