Author Topic: Smoked front and rear turns. Are 1st gen and 2nd gen the same?  (Read 4163 times)
Offline firehawk618
I am looking to purchase front and rear turn signals in a smoked color however I'm finding conflicting information.  Some say 08-10 only, others say 08+ are all the same.
What's the story?  Are the fronts and rears all the same or is the 2nd gen different from first.
Thanks!
http://www.zggtr.org/index.php?topic=952.0
2012 C14 Black
Re: Smoked front and rear turns. Are 1st gen and 2nd gen the same?
« Reply #1 on: May 24, 2013, 11:28:10 PM »
You want to make yourself less visible?  :o
« Reply #2 on: May 25, 2013, 09:13:54 AM »
I believe they're all the same.
Offline firehawk618
« Reply #3 on: May 25, 2013, 10:31:35 PM »
I think so also but want to know for sure before ordering them.
Anyone have a definitive answer to my original question?
Thanks in advance.
2012 C14 Black
Offline firehawk618
« Reply #4 on: May 25, 2013, 10:32:10 PM »
I'm going to just ignore this.
2012 C14 Black
« Reply #5 on: May 25, 2013, 10:59:08 PM »
Thanks in advance.
If they fit a 10 they will fit a 13, same.
« Reply #6 on: May 26, 2013, 06:46:02 AM »
Some say 08-10 only, others say 08+ are all the same.Thanks!
There is no difference in 2010-2013 (other than grab bar and wheel paint colors).  Yet there are lots of differences between gen 1 (2008-2009) and gen 2  (2010+).  So saying "08-10 only" makes no sense at all.
« Reply #7 on: May 26, 2013, 08:31:28 AM »
Just.spray paint them black. ;D
« Reply #8 on: May 26, 2013, 10:12:39 AM »
They probably created their ad in 2010 and just never updated it.
Offline C1xRider
« Reply #9 on: May 26, 2013, 11:27:09 AM »
I put a set on my '10, but had some problems getting things to fit right.  Don't recall now what the issues were, but I think it was with the rear ones.  They did eventually go on, but not without a slight mod (as I recall, I had to swap the lens and use with my existing base).  Then again, when I bought them, the listing included C14 for one set (front?), but not the other.  For the other, the bikes they listed included bikes that also showed to be compatible with C14's in other listings, so I bought them based on that.
Offline RBX QB
« Reply #10 on: May 26, 2013, 12:47:58 PM »
08+ are all the "same".  Ordered mine from http://stores.motolume.com/Categories.bok?category=Kawasaki+Turn+Signals&nval=79, which lists them as 08-12.
2011 Concours 14 ABS
« Reply #11 on: May 26, 2013, 01:56:43 PM »
Good point
« Reply #12 on: May 26, 2013, 05:12:18 PM »
I take it these still light up the same as the OEM's?
Offline firehawk618
« Reply #14 on: May 28, 2013, 03:25:22 PM »
Excellent.  Thanks for the help.
2012 C14 Black
