Author Topic: O'ring stop oil ... maybe!  (Read 10104 times)
Offline MGvaleri
  • Country: it
« on: April 09, 2013, 12:17:07 PM »
In my case I think that depends on such a small oil drip from o'ring.
Later I shall tell you if!
http://youtu.be/8fUm8kaTEC8
MGvalerio  8)
Offline connie1
Re: O'ring stop oil ... maybe!
« Reply #1 on: April 09, 2013, 12:37:09 PM »
Excellent video MG.  If you are correct it would save a lot of messing around in the engine.  Hope you used a quality o-ring.
Man do I love this bike! Red '09
« Reply #2 on: April 09, 2013, 01:05:03 PM »
 :goodpost:   Excellent vid, MG!  So that's another thing I need to check as we've heard of the this sensor leaking oil before...cam position sensor?  If so, I can't find it in the parts fiche..  I know it's there but I just can't locate it.  The service manual shows it with the cylinder head cover and cylinder head and camshaft.
Offline MGvaleri
  • Country: it
« Reply #3 on: April 09, 2013, 01:21:47 PM »
connie1 :)
O'ring is quality, but not with specs as the original, this was my choice, because if I'm a magician per hour!
Without the risk is not resolved I think.
MGvalerio. 8)
« Reply #4 on: April 09, 2013, 01:26:36 PM »
I was rather hoping you used the Kwak o-ring and had a part number..... :doh:
Bullwinkle's hat gag
Instead you came up with something off the shelf as usual....
You MacGyver, you!
Offline MGvaleri
  • Country: it
« Reply #5 on: April 09, 2013, 01:34:22 PM »
You MacGyver, you!
 ;D ;D ;D ciao jim
MGvalerio. ;)
Offline connie1
« Reply #6 on: April 09, 2013, 02:00:33 PM »
I wouldn't have used the stock ring either.  It has already proven to be too small or damaged.  Use a quality o-ring, one size bigger, and be careful with the installation, should look after the problem for good.
« Reply #7 on: April 09, 2013, 02:13:42 PM »
Maybe that's why it can't be found in the parts fiche....  There's o-rings and then there's o-rings.  This one must withstand heat and petroleum products.  Not sure I'd trust picking one up from a bin in a hardware store..  While the original one does shrink and leak a bit, it's not a catastrophic failure.  This one tends to leak (from my research) the more the bike sits.  If the bike is ridden regularly then not so much.  So I guess riding the bike is good for it and you.
Offline MGvaleri
  • Country: it
« Reply #8 on: April 09, 2013, 03:34:43 PM »
O-Rings by Material» EPDM 70 NSF
» FFKM Perfluoroelastomer
» FKM Viton 75 Black
» FKM Viton 75 Brown
» FKM Viton 90 Black
» HNBR 70
» Neoprene CR70
» Nitrile BN70
» Nitrile BN70 FDA
» Nitrile BN90
» Polyacrylate PA70
» PolyUrethane PU70 Industrial Use
» PolyUrethane PU90 Industrial Use
» PolyUrethane PU70 For Paintball Markers
» PolyUrethane PU90 For Paintball Markers
» Silicone S70 FDA Red
» PTFE Solid O-Ring White
» Quad Rings
O-Rings By Sizes» Metric Size
» Inch Size
O-Rings By Application» Chemical - General
» Chemical - Extreme
» Drive Belt
» Food - FDA
» Fuel - Diesel
» Fuel - Gasoline
» Fuel - Jet
» Fuel - MTBE
» Gas - Helium
» Gas - LPG
» Gas - Natural Gas
» Gas - Atmosphere Ozone
» Gas - High Temperature
» Hydraulic Fluid
» Lube - Aerospace
» Lube - Automotive
» Water - NSF
» Water - Beer, Whisky, Wine
» Water - General
» Other Application Not Listed
 Kits» O-Rings Kits
» Make Your Own Rubber Kits
» Splice Kits
» Lubes, Measuring Cones, Calipers, Extractors
    Military and Aerospace» AS3578 (Aerospace Nitrile)
» AS3582 (Aerospace Silicone)
» M25988/1 (FluoroSilicone 70)
» M25988/2 (FluoroSilicone 75)
» M25988/3 (FluoroSilicone 60)
» M25988/4 (FluoroSilicone 80)
» MS35489 Grommet
» M83248/1 (Military Viton 75)
» M83248/2 (Military Viton 90)
» M83485/1 (Military Viton GLT)
» M83461/1A (Nitrile)
» MS28774 (PTFE Split Backup)
» MS28775 (Nitrile Nitrile 75)
» MS28778 (Military Nitrile 90)
» MS29513 (Nitrile Nitrile 65)
» NAS1611, NAS1612 (Aerospace EP)
Caps and Plugs» DFPP - Dimpled Flanged Pull Plugs
» EPP - EPDM Pull Plugs
» HSWP - Hollow Silicone Washer Plugs
» HTPS - Hollow Tapered Plugs Silicone
» RS-SBR - Black Rubber Stoppers
» RS-SIL - Silicone Rubber Stoppers
» RS-SIL-CLR - Silicone Rubber Stoppers Clear
» SC - Silicone Caps
» SFLP - Silicone Flangeless Plugs
» SFP - Silicone Flanged Plugs
» SPH - Silicone Plugs with Handles
» SPP - Silicone Pull Plugs
» SRC - Silicone Rectangular Caps
» SSP - Silicone Step Plugs
» ST - Silicone Tubing
» STM - Silicone Thread Mask
» SWC - Silicone Washer Caps
» SWP - Silicone Washer Plugs
» SWPP - Silicone Washer Pull Plugs
» TPE - Tapered Plugs EPDM
» TPS - Tapered Plugs Silicone
References» Custom Molded Rubber Quote
» Engineers Only
» Material Selection
» Size Chart
» Shelf Life
» Terms
MGvalerio.0
« Reply #9 on: April 09, 2013, 04:08:48 PM »
 :doh: ;D   I sit vindicated.
Offline JerBear
« Reply #10 on: April 09, 2013, 04:11:23 PM »
MG do you have a Part#and Manufacturer for the O-ring you did use? The new larger one?
2008 C14 Non-ABS
Offline Xelvic
« Reply #11 on: April 09, 2013, 04:41:43 PM »
Awesome video! ;)
2012 Kawasaki Concours 14
Offline Shoe
« Reply #12 on: April 09, 2013, 06:23:21 PM »
connie1 :)
.............., this was my choice, because if I'm a magician per hour!
MGvalerio. 8)
Someone please translate.
PS. I did not see any evidence that mine was leaking. I did however, have valve cover gasket leakage.
Eat corn. Drill for oil.
2008 Concours, 2010 Goldwing
Offline connie1
« Reply #13 on: April 09, 2013, 08:52:04 PM »
without the risk is not resolved I think.
I gather that to mean that without going to the larger o-ring (risking the change) it wouldn't fix the problem.  I may be wrong.  The magician part ... I couldn't hazard a guess.
Offline MGvaleri
  • Country: it
« Reply #14 on: April 09, 2013, 11:50:32 PM »
Mi piace moltissimo questo Forum,peccato che mi capiate al 50% di quello che scrivo,questa colpa mia,io sono venuto da voi.
Connie 1  :thumbs: OK a 80%.
MGvalerio. :(
« Reply #15 on: April 10, 2013, 04:31:55 AM »
If you eat more fruit that should help with that problem.
« Reply #16 on: April 10, 2013, 04:59:54 AM »
That wasn't a typo!  >:( ;)
« Reply #17 on: April 10, 2013, 05:01:10 AM »
« Reply #18 on: April 10, 2013, 06:36:42 AM »
Orings didn;t fix the prob on my ZX14...and you guys are scaring me with these C14 leaky Kawasaki  :censored: bikes!
I could be riding a leaky Hardly-Ableson slow with a dew rag!  ;D
« Reply #19 on: April 10, 2013, 07:00:43 AM »
It's under the fuel injection fiche. :banghead:  Part number 92055-1639 There are two of them, the one in the front as seen in the video
and one on top of the cylinder head cover, aka valve cover.
