There's o-rings and then there's o-rings.
O-Rings by Material» EPDM 70 NSF
» FFKM Perfluoroelastomer
» FKM Viton 75 Black
» FKM Viton 75 Brown
» FKM Viton 90 Black
» HNBR 70
» Neoprene CR70
» Nitrile BN70
» Nitrile BN70 FDA
» Nitrile BN90
» Polyacrylate PA70
» PolyUrethane PU70 Industrial Use
» PolyUrethane PU90 Industrial Use
» PolyUrethane PU70 For Paintball Markers
» PolyUrethane PU90 For Paintball Markers
» Silicone S70 FDA Red
» PTFE Solid O-Ring White
» Quad Rings
O-Rings By Sizes» Metric Size
» Inch Size
O-Rings By Application» Chemical - General
» Chemical - Extreme
» Drive Belt
» Food - FDA
» Fuel - Diesel
» Fuel - Gasoline
» Fuel - Jet
» Fuel - MTBE
» Gas - Helium
» Gas - LPG
» Gas - Natural Gas
» Gas - Atmosphere Ozone
» Gas - High Temperature
» Hydraulic Fluid
» Lube - Aerospace
» Lube - Automotive
» Water - NSF
» Water - Beer, Whisky, Wine
» Water - General
» Other Application Not Listed
Kits» O-Rings Kits
» Make Your Own Rubber Kits
» Splice Kits
» Lubes, Measuring Cones, Calipers, Extractors
Military and Aerospace» AS3578 (Aerospace Nitrile)
» AS3582 (Aerospace Silicone)
» M25988/1 (FluoroSilicone 70)
» M25988/2 (FluoroSilicone 75)
» M25988/3 (FluoroSilicone 60)
» M25988/4 (FluoroSilicone 80)
» MS35489 Grommet
» M83248/1 (Military Viton 75)
» M83248/2 (Military Viton 90)
» M83485/1 (Military Viton GLT)
» M83461/1A (Nitrile)
» MS28774 (PTFE Split Backup)
» MS28775 (Nitrile Nitrile 75)
» MS28778 (Military Nitrile 90)
» MS29513 (Nitrile Nitrile 65)
» NAS1611, NAS1612 (Aerospace EP)
Caps and Plugs» DFPP - Dimpled Flanged Pull Plugs
» EPP - EPDM Pull Plugs
» HSWP - Hollow Silicone Washer Plugs
» HTPS - Hollow Tapered Plugs Silicone
» RS-SBR - Black Rubber Stoppers
» RS-SIL - Silicone Rubber Stoppers
» RS-SIL-CLR - Silicone Rubber Stoppers Clear
» SC - Silicone Caps
» SFLP - Silicone Flangeless Plugs
» SFP - Silicone Flanged Plugs
» SPH - Silicone Plugs with Handles
» SPP - Silicone Pull Plugs
» SRC - Silicone Rectangular Caps
» SSP - Silicone Step Plugs
» ST - Silicone Tubing
» STM - Silicone Thread Mask
» SWC - Silicone Washer Caps
» SWP - Silicone Washer Plugs
» SWPP - Silicone Washer Pull Plugs
» TPE - Tapered Plugs EPDM
» TPS - Tapered Plugs Silicone
References» Custom Molded Rubber Quote
» Engineers Only
» Material Selection
» Size Chart
» Shelf Life
» Terms
MGvalerio.0
