Author Topic: Transmission fluid to the tank ?  (Read 11661 times)
Offline JhVenezuela
  • Country: ve
« on: November 07, 2012, 11:13:24 AM »
Hi !!!!
A friend of mine add 500 cc of transmission fluid to the Gas tank (BMW GS-1200)
every time he refill
According to him, this keep the valves, Gas bump and the Fuel system always lubricating.
Is that correct ?
Offline PH14
Re: Transmission fluid to the tank ?
« Reply #1 on: November 07, 2012, 11:41:55 AM »
500cc  :yikes:
 :popcorn:
« Reply #2 on: November 07, 2012, 11:43:10 AM »
Your friend will stand a good chance of poisoning the catalytic converter and the O2 sensor (if that bike has one), building up carbon inside the combustion chambers and spark plugs, carbon up the valves and ruining the spray pattern of the fuel injection nozzles.
Other than that, he's good to go.  :o
« Reply #3 on: November 07, 2012, 11:47:30 AM »
 :yikes: :yikes: :yikes: :yikes: :yikes:   My goodness, that's equivalent to a pint!  Pints are for drinking, not putting in gas tanks.
« Last Edit: November 07, 2012, 02:54:17 PM by VirginiaJim »
Offline Mister Tee
« Reply #4 on: November 07, 2012, 11:48:02 AM »
Agreed, horrible idea.
That said, it's a common trick with diesel engines to reduce injection pump wear.
Offline sherob
« Reply #5 on: November 07, 2012, 01:03:51 PM »
Does he have deer whistles on his bike too?  :o
Rob
Offline mike-s4
« Reply #6 on: November 07, 2012, 02:44:34 PM »
Transmission oil is for transmissions. Says it right on the label.
Put gasoline in the gas tank. (see owners manual)
Offline PH14
« Reply #7 on: November 07, 2012, 04:17:41 PM »
 :goodpost:  :rotflmao:
Offline mike-s4
« Reply #8 on: November 07, 2012, 05:57:33 PM »
New thread?
Top 10 things you should not put in the gas tank!
1- Water (h2o)
2- Brake oil
3- Rocks (gravel dirt etc...)
4- Hamsters, mice (or any animal that fits in the hole)
5- Ammunition
6- Hair (pubic, head etc)
7- Pens, pencils. (writing implements)
8- Heroine (See easy rider movie)
9- Explosives
10- Transmission oil
Offline RBX QB
« Reply #9 on: November 07, 2012, 06:18:14 PM »
Maybe he does ground aerobatics. Enough fluid burning out of the exhaust and you leave a really cool smoke trail to show where you've been.
2011 Concours 14 ABS
Offline Mojoh
« Reply #10 on: November 07, 2012, 07:26:01 PM »
New thread?
1- Water (h2o)
2- Brake oil
5- Ammunition
9- Explosives
11 - Diesel Fuel
« Reply #11 on: November 07, 2012, 08:12:55 PM »
A little bit of Marvel Mystery oil  now and then maybe, but anything else I would stay away from.
Offline PH14
« Reply #12 on: November 07, 2012, 08:43:00 PM »
But not 500cc.  :o
Offline C1xRider
« Reply #13 on: November 07, 2012, 09:22:19 PM »
Wow, 500cc's is way too much, of any kind of oil, unless you are pre-mixing for a 2-stroke engine, with 2-stroke oil!
Oil in the fuel will also raise the combustion chamber temperature.  On 2-strokes, you can melt pistons if you use too much oil.
Certainly would NOT recommend adding any oil to the fuel on your C14.
« Reply #14 on: November 07, 2012, 09:28:06 PM »
But not 500cc.  :o
More like a few drops.  ;)
« Reply #15 on: November 08, 2012, 05:09:31 AM »
1- Water (h2o)
2- Brake oil
5- Ammunition
9- Explosives
12- Sexual Organs.  :rotflmao:
« Reply #16 on: November 08, 2012, 06:44:13 AM »
 :yikes:
« Reply #17 on: November 08, 2012, 07:35:17 AM »
« Reply #18 on: November 08, 2012, 08:18:22 AM »
Do you speak from experience?
« Reply #19 on: November 08, 2012, 04:16:36 PM »
...he thought she said gashole.
