Author Topic: tire monitors for c14  (Read 8761 times)
Offline Bill
« on: October 25, 2012, 04:36:29 PM »
Has anyone tryed to change the battries in there tire monitors?
Re: tire monitors for c14
« Reply #1 on: October 25, 2012, 05:27:15 PM »
Yes.
« Reply #2 on: October 25, 2012, 06:14:07 PM »
Must have just joined to ask that.
« Reply #3 on: October 25, 2012, 06:33:46 PM »
Yes.
« Reply #4 on: October 25, 2012, 06:37:53 PM »
To start...  http://www.zggtr.org/index.php?topic=6071.0
Max, I expect you to do the rest....  I'm starting to drink so I won't be much good in a bit....
« Reply #5 on: October 25, 2012, 06:44:21 PM »
Check out the thread Jim posted and here is another one.
http://www.zggtr.org/index.php?topic=301.30
« Last Edit: October 26, 2012, 04:19:53 AM by Tom V »
« Reply #6 on: October 25, 2012, 08:30:02 PM »
You'll need to be a little more specific about what time of day it is Sparky...  ;)
« Reply #7 on: October 26, 2012, 03:58:35 AM »
« Reply #8 on: October 26, 2012, 03:15:28 PM »
I am tired of it already.  I think you should nuke the redundant threads and just send PM links to the search box...
« Reply #9 on: October 26, 2012, 03:28:52 PM »
knowing how to use search tools should be a mandatory membership prerequisite too
« Reply #10 on: October 26, 2012, 03:32:42 PM »
That's no way to treat the new guy.
www.justfuckinggoogleit.com     :o
« Reply #11 on: October 26, 2012, 03:45:00 PM »
Where's Bill?
« Reply #12 on: October 26, 2012, 05:56:47 PM »
Oh come on now, Max.  You're really good at pulling up those links... :)
« Reply #13 on: October 26, 2012, 10:40:30 PM »
+1...
Tru dat, change your name from Max to Bing, if anyone needs a thread search Max (aka Bing) always delivers...  ;) :) :thumbs:
« Reply #14 on: October 27, 2012, 08:52:16 AM »
a noble service, its obvious the forum needs a human search engine
Offline olie
« Reply #15 on: October 27, 2012, 10:35:22 AM »
why not "merge" all those common threads? Jim?
13 Blue Connie, 8/4/2013
16 Green Versys 1k
11 Red Vette
« Reply #16 on: October 27, 2012, 12:40:03 PM »
I'm not going to 'merge' them as such but I try to move mostly dead threads (little or no activity) that have a wealth of information into the C14 Wiki area...  Problem is I need to get time to do it as it's somewhat of a manual process.  Using search helps some but we don't use the same terms for what we talk about.  That plays heck with the search engine (digital and human).
« Reply #17 on: October 27, 2012, 04:04:27 PM »
Indeed.  Searching can be frustrating for any number of reasons.  Terminology is the primary cause of failure- when people use different words for the same thing.  I can very much appreciate when people can't find something and try to help (on several forums).  What I don't appreciate is when people never even try to search and, instead, just start a new thread on a topic that has been discussed over and over.  Those not only waste time, they create a lot "noise" when searching.
I found it especially irritating when the settings in this forum used to actually COMPLAIN when you tried to post to a thread not even a year old- encouraging the user to create yet another thread/topic.  Thankfully it has been adjusted to be a year:
"Warning: this topic has not been posted in for at least 365 days.
Unless you're sure you want to reply, please consider starting a new topic. "
Of course there are cases where a new topic/thread is indicated, but it generally better to pull back existing stuff so there is continuity.  (Yet there can be a lot of noise in threads too that make it hard to perform research... even this post is noise, since it is not related to "tire monitors").
« Reply #18 on: October 27, 2012, 04:27:04 PM »
could change the post title to 'tire THREAD monitors'  ;)
« Reply #19 on: October 27, 2012, 09:20:11 PM »
Just delete them before they even get rolling, no more need for them other than to bitch.
