Author Topic: tire monitors for c14  (Read 8766 times)
Offline kscharnberg
Re: tire monitors for c14
« Reply #20 on: January 31, 2013, 10:19:14 AM »
does any one know if these tps battreies have a shelf life. just had one replaced with a 09 date on the box and worked for about an hour
« Reply #21 on: January 31, 2013, 11:03:47 AM »
Kawi says 5 years max. Why didn't you get a newer monitor?
Offline kscharnberg
« Reply #22 on: January 31, 2013, 01:39:05 PM »
Thats the only one they had at the time. they are going to replace it again under warranty.
« Reply #23 on: January 31, 2013, 02:27:16 PM »
See if they'll let you keep the bad one. Replace the battery and keep it for a spare.
« Reply #24 on: January 31, 2013, 02:40:50 PM »
Offline Tremainiac
« Reply #25 on: January 31, 2013, 06:33:41 PM »
Soooo... Did VirginiaJim get an answer or just scared off?
« Reply #26 on: February 01, 2013, 04:11:56 AM »
Answer to what?  Bear with me as I just woke up and not at my best....well, I'm never at my best but what the heck, eh?  I am the best at being me, though.
« Reply #27 on: February 01, 2013, 04:26:16 AM »
Keep up the good work Robin!    :)
« Reply #28 on: February 01, 2013, 04:28:25 AM »
Aye aye guv'nr.
Offline jonathan
« Reply #29 on: February 01, 2013, 08:59:29 AM »
This is a spare that would require the ECU to be reprogrammed in order to use. Much easier to replace the batteries in the TPMs that the system already recognises.
« Reply #30 on: February 01, 2013, 10:06:50 AM »
Would you have to reprogram? And if you did it will be cheaper than replacing the sensor out of pocket after warranty.
