Author Topic: good replacement hdlt bulbs?  (Read 13199 times)
Offline h2smokin
« on: September 22, 2012, 06:01:50 PM »
Looking for descent set of bulbs for my headlights and a source maybe? I had a pair of the bulbs from murphs but they did not last long. I figure maybe 150hrs before both low beams went out . Now down to just the highs or swap back to the stockers I kept. Any other descent bulbs out there I can try . I'd try to get some hid's but I'm no good at electrical stuff although willing to try . I heard they've come down in price and at $60 a pair regular ones it might be worth a try. Thanks
Offline Mad River Marc
  • The Kipass shall inherit the earth
Re: good replacement hdlt bulbs?
« Reply #1 on: September 22, 2012, 06:22:48 PM »
I had the murphs bulbs in for almost 2 years and 22k miles before one of them died.....  Could that have been a fluke?
« Reply #2 on: September 22, 2012, 06:32:22 PM »
I didn't have much luck with them, either.  Very short lived from what I remember.  I went back to the stockers.
« Reply #3 on: September 22, 2012, 06:44:48 PM »
Murph doesn't make the bulbs, he just sells them. ;)  Stock bulbs seem fine to me, will probably just stick with them.
« Reply #4 on: September 22, 2012, 07:11:27 PM »
Really?
Offline connie and me
« Reply #5 on: September 22, 2012, 07:23:18 PM »
Had pretty good luck with Silver stars, lasted over 4yrs in my Vstrom, with significant better light output, actually, that rather ugly Suzuki front end had the BEST stock light housings ive ever ridden! better than my new c-14, I ride at night at least once a day, (commuting)
2012 Black
« Reply #6 on: September 22, 2012, 07:28:56 PM »
Really?
Wasn't 100% sure you knew that. :loco:
« Reply #7 on: September 22, 2012, 07:48:44 PM »
Appreciate it..
Offline Spanky
« Reply #8 on: September 22, 2012, 09:29:02 PM »
I used the bulbs from murph as well. I had three of them go out in what I consider to be a very short time for a bulb. Installed an HID kit that has as many miles as the other three bulbs put together and still on the original HID bubls.
« Reply #9 on: September 22, 2012, 09:39:48 PM »
I have been using "Murphs" (Phillips) bulbs now for over a year, no prob.  But I probably ride much less than you do.  If I get annoyed, I will probably finally break down and install an HID kit.
« Reply #10 on: September 22, 2012, 10:50:07 PM »
 :thumbs:
Offline h2smokin
« Reply #11 on: September 23, 2012, 09:18:42 AM »
Is there a relatively easy plug and play type HID kit out there? I may just say screw it and get it over with . I've heard the lighting is great and when I do ride long distance it is usually an overnight ride to avoid people and traffic .
« Reply #12 on: September 23, 2012, 10:03:53 AM »
I have the HID kit from A&R and am very happy with it.  :)
http://www.aandrmotorsport.com/store/index.php?dispatch=products.view&product_id=1426
http://www.aandrmotorsport.com/directions/concourshidinstructions.html
Offline Spanky
« Reply #13 on: September 23, 2012, 10:07:45 AM »
The A&R is the same kit I have too.
« Reply #14 on: September 23, 2012, 10:17:05 AM »
I would love to have that HID kit, however the install looks like a pain in the arse and I don't feel like attempting to do it. :-[
« Reply #15 on: September 23, 2012, 11:07:11 AM »
Yeah, that is what was holding me back too.  Having to go straight to the battery and having to use two ballasts and two igniters makes it much more complex.  It is too bad a kit couldn't be invented that somehow could use a single ballast/igniter box that runs both bulbs and pull the power it needs from the stock connectors.
I already know one day I will do it, but right now, laziness wins.
Offline h2smokin
« Reply #16 on: September 23, 2012, 11:43:31 AM »
is that a complete kit for both lights ? Not that bad $ if it works good coupled with the auxillary lights I want I'll be good to go
Offline CigarSki®
  • Newb again?
« Reply #17 on: September 23, 2012, 12:19:14 PM »
Same here, but went with the Silverstar Ultra. The Philips bulbs didn't last all that long for me. +1 on the V-Strom having the best lighting. One of the things I miss from the DL1000. If you take some time to get the aim / level, correct; the C14s work pretty well. May move up to the A&R Hids at some point,
Wayne Sikorski aka CigarSki
2010 ZG1400 - South Jersey
COG 9250
Offline Spanky
« Reply #18 on: September 23, 2012, 01:47:53 PM »
The install is fairly simple. If a mechanic installs it for you, it should not cost more than 1 to 1.5 hours labor for the install.
Offline wroman
  • 2012 C14
« Reply #19 on: September 23, 2012, 05:49:48 PM »
  My source for quality halogen bulbs.
http://www.rallylights.com
I always wanted to be somebody......I guess I should have been more specific.
