Author Topic: Rear drive oil  (Read 3208 times)
Offline MetrickMetal
    • MetrickMetal Custom Motorcycle Parts
Rear drive oil
« on: September 11, 2012, 09:44:30 PM »
Has anyone used any Amsoil 75w-90 long life synthetic gear oil in the rear drive unit on a C10, as I have a qt of it left over from my VTX1800C in which it worked great for nearly 70k, and It should work just as well for rear drive oil on the C10 I'm resurecting.
www.MetrickMetal.com custom motorcycle parts
Custom naked 07 Suzuki Bandit GSF1250S/AK7
In the process of resurrecting an 02 C10
Offline midnightrider
Re: Rear drive oil
« Reply #1 on: September 12, 2012, 03:52:46 AM »
Should be just fine. I've used 75w-90 in synthetic and semi-synthetic with no issues. I just rolled over 75,000 miles.   :popcorn:
2004 C10 RIP
Re: Rear drive oil
« Reply #2 on: September 12, 2012, 12:35:48 PM »
Thanks, and I figured it would be ok, as rear drive units are pretty much all the same.  ;)
Offline Summit670
Re: Rear drive oil
« Reply #3 on: September 13, 2012, 06:52:09 AM »
I didn't check the specs but just make sure if it calls for GL4 that you use GL4 rated oil.  I think the Connie is GL5.
Arctic Cat M8 163 rules
Re: Rear drive oil
« Reply #4 on: September 13, 2012, 07:42:39 AM »
The Amsoil synthetic gear lube I have is rated GL5, but can also be used in any gear application where a GL4 gear oil is specified.  ;)
Re: Rear drive oil
« Reply #5 on: September 13, 2012, 10:45:35 PM »
Connie likes GL5. Page 88 in the owners manual. ;)
2004 C10 RIP
Offline Electroken
Re: Rear drive oil
« Reply #6 on: September 14, 2012, 04:05:45 AM »
That is what's in mine now.
Offline Cholla
Re: Rear drive oil
« Reply #7 on: September 14, 2012, 05:34:48 AM »
Gl5 is backwards comptible. It exceeds the requirements of GL4.
Offline Necron99
    • Facebook Page
Re: Rear drive oil
« Reply #8 on: September 14, 2012, 05:53:52 AM »
I too have the same Amsoil oil, also left over from my VTX 1800C.  :)
I add guard dog moly to mine.  I know it's probably overkill....
-Dylan Thomas
2010 ZG1400 COG #9384
