Author Topic: changing head lights C 14 2010  (Read 5480 times)
Offline bombsquad1201
  • Robots know blue is faster
« on: August 14, 2012, 09:45:40 AM »
Hey Gang,
Any shortcuts or things I need to know about replacing a burnt out bulb.
Thanks, for the help.
PS I have a manual Jim.
Re: changing head lights C 14 2010
« Reply #1 on: August 14, 2012, 09:48:22 AM »
From Brian's (BDF) post on the other forum.
"Pull the center plug straight back and off the lamp. Then grab the rubber sealing ring by the top and bottom tabs and pull it back to remove. Finally, there is a wire bent around the back of the lamp holding the lamp in the headlight housing: Push in slightly and down to move the spring wire away from the retaining latch and it will pivot toward the back of the light and out of the way. The lamp is now free. The lamps (bulbs) are timed so they only go in one way, when you replace the lamp rotate it gently until it drops into the proper position. Then replace the spring retainer, the rubber sealing ring and the plug itself.
It takes longer to type it than to do it but there is a learning curve, especially since you cannot really look at the assembly while your hand is in there."
« Reply #2 on: August 14, 2012, 10:20:18 AM »
Takes 5-10 seconds to change per above.
I like the NAPA bulbs. I pull up to store, remove the burnt one, walk in, walk out and put in new one.
Takes longer for the guy to ring it up than replace.
Tip:  don't touch the glass with your bare fingers.
« Reply #3 on: August 14, 2012, 01:45:11 PM »
I stick my arm in and wiggle about a bit and eventually get the bulb out and replaced.  There's a rubber thingy and some metal wire that have to go back right and I think one tang (not the astronaut drink) is larger than the others.  Then do the other side.
« Reply #4 on: August 14, 2012, 01:48:33 PM »
So what you're saying is I can't drink anything (alcohol related) during this procedure unless I wear gloves?  I don't drink from plastic, you know.  It just doesn't taste right to me.
« Reply #5 on: August 14, 2012, 01:49:47 PM »
A can of beer will do in a pinch.
« Reply #6 on: August 14, 2012, 01:54:22 PM »
Beer comes in cans?
« Reply #7 on: August 14, 2012, 02:12:52 PM »
C'mon Jim, we are trying to keep this simple- no need for all the technical jargon.
« Reply #8 on: August 14, 2012, 02:14:37 PM »
« Reply #9 on: August 14, 2012, 02:22:10 PM »
« Reply #10 on: August 14, 2012, 02:23:16 PM »
« Reply #11 on: August 14, 2012, 02:24:02 PM »
What are you laughing at?  >:(
« Reply #12 on: August 14, 2012, 02:29:26 PM »
Oh nothing, nothing at all Sir Robin.
Get your arm out of that thing and have one of these.
« Reply #13 on: August 14, 2012, 02:32:11 PM »
Looks interesting and in my line of work.  Where do you get them?
« Reply #14 on: August 14, 2012, 02:34:03 PM »
I would think, in your line of work, that you would know?
http://www.blacksheepbrewery.com/beers/holy_grail_bottled_beer/
Ten years later on the 40th anniversary Holy Grail is still going strong. With more hops than a killer rabbit, it's a full-flavoured golden ale with a distinctively fruity flavour followed by the Black Sheep signature dry finish.
Aroma
Dangerously fruity against a biscuity malty background.
Taste
You can always taste the difference when an ale has been tempered by burning witches. In this respect Holy Grail certainly doesn’t disappoint with its clean zesty flavour and long crisp bitter finish.
Ingredients
We brew Holy Grail with Maris Otter malt, an old and expensive variety that is renowned for the taste and the quality of the beer it produces.
A mixture of old English Hop varieties including a touch of WGV hops gives Holy Grail its lovely fruity nose.
Spamalot
2009 was the 40th anniversary of Monty Python and the 10thanniversary of our Holy Grail. To celebrate we are currently supplying the beer in all theatres showing the hit musical “Spamalot” on the nationwide tour.
Did You Know…
That Holy Grail is our most popular beer in the US and Canada?
All our bottled ales are suitable for both vegetarians and vegans.
Awards
2006 Favourite Import Ale - the Canada Cup of Beer
« Reply #15 on: August 14, 2012, 02:36:06 PM »
This is almost better than an oil or exploding driveshaft thread
« Reply #16 on: August 14, 2012, 02:37:14 PM »
Oh, it's going to get better.  Things have been too quiet lately.
The closest establishment to me is Bully's Restaurant and Pub (126.9 miles) in Columbia, PA.  $6 for a bottle.  That's a bit steep.  I think I'll keep to drinking my normal swill or just go to straight liquor.
« Reply #17 on: August 14, 2012, 03:48:42 PM »
Yeah, good grief!!
Flathead
« Reply #18 on: August 14, 2012, 04:05:02 PM »
Total Wine (totalwine.com) in richmond, $9 for a six pack.  If you ever get a chance try the Black Sheep Rigwelter, outstanding! The definition of rigwelter is also quite humourous ;)
« Reply #19 on: August 14, 2012, 04:31:47 PM »
Hmmm, we have one of those stores in F'burg.  Time for a field trip.
