Author Topic: ram ball mount  (Read 2757 times)
Offline okxd45
ram ball mount
« on: July 02, 2012, 09:42:35 AM »
Need a ram ball mount for Helibars.
Jeff
Offline Eddie
  • BANNED
Re: ram ball mount
« Reply #1 on: July 13, 2012, 01:10:40 PM »
check gpscity.com
Offline okxd45
Re: ram ball mount
« Reply #2 on: July 13, 2012, 02:44:27 PM »
Thanks, I'll check it out.
Jeff
Re: ram ball mount
« Reply #3 on: July 16, 2012, 04:19:42 AM »
Offline okxd45
Re: ram ball mount
« Reply #4 on: July 16, 2012, 09:28:09 PM »
They look like these...(1.75 in)
I really don't know what I need (how a ram ball mount goes together) to attach my phone (HTC EVO) so that I can have GPS.  Any ideas?
Jeff
Re: ram ball mount
« Reply #5 on: July 19, 2012, 08:52:19 AM »
Looks like the ones I just removed.  They should have a screw hole for a screw in ram mount.  When I bought mine, I also bought the ram mount accessory.  I don't know if the ram mounts have different thread sizes.  I could check mine and see what the size of the screw portion but it won't be until this weekend.  Out on a job now.
Offline okxd45
Re: ram ball mount
« Reply #6 on: July 19, 2012, 03:40:55 PM »
Ok sounds good. :)
Jeff
Re: ram ball mount
« Reply #7 on: July 21, 2012, 01:22:05 PM »
In checking the threads on the ram ball that screws into the Heli 1 3/4 risers, it appears to be 3/8 16tpi.  You may want to buy a bolt with those specs and try it first, though.  I'm surprised a bit they weren't metric.
Offline okxd45
Re: ram ball mount
« Reply #8 on: July 21, 2012, 06:56:24 PM »
Ok will check it out.  Thanks!
Jeff
Offline Eddie
  • BANNED
Re: ram ball mount
« Reply #9 on: July 29, 2012, 12:36:22 PM »
This is the model you want if you want to use one of your existing handlebar clamp bolts for the ball.
http://www.gpscity.com/ram-mount-motorcycle-handlebar-clamp-ram-b-367u.html
