Author Topic: Why doesn't the green neutral light come on / why does it go on-off-on-off...  (Read 3137 times)
Offline Uded2me
« Last Edit: February 21, 2016, 09:06:09 PM by knight_mare »
Offline Rick Hall
  • Eruption
That's the switch. Dousing it w/ WD-40 will make the outside look all purdy on the OUTSIDE. I don't recall the switch being 'wet' (in  oil), but there' no mention of any sealing agent when replacing it.
You might also check to ensure the wire cap is making good contact w/ the switch before removing the switch for further analysis. I remember it (the wire connector) as a psudo bullet connector. Pinch it every so gently if it's making a poor connection.
Rick
Offline Uded2me
This forum is dead dead dead
« Reply #2 on: May 24, 2011, 06:06:50 PM »
d e a d
« Last Edit: February 21, 2016, 09:06:13 PM by knight_mare »
Offline 2001concours
    • 2001concours website
I have found an aerosol contact cleaner that blasts away corrosion. That followed up by some WD-40 does the trick on most connections and dirty switches.
2001 Concours with 90k miles, heavily modified.
Lots of how to images on my webshots folders
http://community.webshots.com/user/2001concours
Offline snarf
Funny thing about WD-40; it make a much better cleaner than it does a lubricant :o
2002 Conc
1986 Conc "The spirit of COG"
