Since I drilled a hole in my tire I can't ride until I get a new one installed, but until then I have this question that is a continuation from the old forum. A couple of weekends ago I pulled my fairing apart. The only part I didn't completely remove is the nose piece. I examined the bracket and did not see anything that looked cracked or broken, even using a spotlight so I could see everything clearly. I even jerked it around and nothing. I made sure that bolts for the bracket were tightened down. The front bolt I had already tightened a week or so before as it was pretty loose.
Anyplace that I could see that could take a wrench had one put to it. I checked the instrument cluster, all the nuts around both mirror mounting locations. I did find one area that had no screws in it at all. Nobody was ever able to tell me the name of it and I cannot find it in the parts fiche. It looks like it may be part of the #16146-COVER-ASSY,INNER COWLING,FR. This is it:
I also found the right damper (92075/92075A) was loose. I used a washer to tighten both it and the the left one (as a precautionary procedure). There was nothing as far as I know that did not get tightened, yet I still get the rattle. When I go over small bumps like expansion joints on the bridge I get the banging. I know someone else said that their fairing was quite but mine isn't. To be honest I am not certain that I didn't have it before, but it is something I notice now and it just seems that it shouldn't make the noise it does. Anybody have any ideas on what to quite it down?
