I have a project underway and need some info from those that are 'in the know'.
I have an '05 that needs all fairing parts including fairing stay. In my quest, I need to know if I can consider ALL C10 years as potential doners to: Put 94 & Newer style gauges and inner fairings with 93 & Older outer fairing parts. Biggest question is the fairing stay / bracket.
Here's what I know (or THINK I know):
- I'm 99.9% sure that the outer fairing parts are identical for fitment, but would like to confirm.
- The inner fairings / gauges are obviosly not compatible for any mix and match.
- the fairing stay has a different part no. between the 2 generations and MAY have some different mount brackets and tabs - but I'm not certain of this.
The $64,000 question: Will a 93 & Older fairing stay / bracket accomodate the 94 & Newer gauges and inner fairing pieces?
If not, would a reasonable amount of reverse (forward?) engineering and fabrication for those mount points make it work?
