Author Topic: WTB Racetech Cartridge Emulators  (Read 2855 times)
Offline turbojoe78
« on: November 13, 2011, 06:19:32 PM »
Hi,  I'm looking for some Racetech Cartridge Emulators for a 1999 C10 for a winter project.
Thanks,
Joe
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: WTB Racetech Cartridge Emulators
« Reply #1 on: November 13, 2011, 07:10:03 PM »
joe - when you get them, my best setup is 4 holes in the blow-off plate, blue springs w/ 2 turns preload. I also run stock springs with about 5" cut from the tightly wound end. sweet! steve
Offline turbojoe78
« Reply #2 on: November 14, 2011, 05:27:29 PM »
Thanks Steve,
I've got 4" cut off my stock springs now, weigh 180 lbs and do almost all of my riding alone.
Do you think I should cut the additional inch off or will I be ok with just 4" cut off?  Joe
« Reply #3 on: November 14, 2011, 07:37:31 PM »
That's going to fine, I think. I weigh a little (ahem) more than you... :o Steve
Offline yoman
« Reply #4 on: November 15, 2011, 08:16:07 AM »
Okay, maybe the wrong place but........what did you use to make up the difference in the spring length once you cut it? which end did you cut?
2002 Semi-naked Connie
Offline turbojoe78
« Reply #5 on: November 15, 2011, 02:48:28 PM »
PM sent
Offline RFH87_Connie
« Reply #6 on: November 17, 2011, 12:30:24 PM »
Here is a quote from somewhere I saved and is what I (and others) have done:
The stock fork oil is called 10W-20 in the service manual.  The biggest bang for the buck is the change the oil to 15w fork oil and to cut 4-6" of the closest spring coils off of the OEM springs and substitute the coorect length of 3/4" SD-40 PVC pipe to get the spring length back to specs (see attached image). Grind the end of the cut spring flat and protect each end of the PVC with a steel washer (slightly less than 1.25” OD).  Make all cuts square.  Adjust the length of PVC and the adjuster to get 1-3/8" static sag (droop, fork compression) with you on the bike.
