Author Topic: Removing Float Bowl  (Read 3581 times)
Offline turbojoe78
Removing Float Bowl
« on: November 11, 2011, 09:57:52 AM »
I'm trying to remove my #4 float bowl to clean my float needle and seat to stop a leak without removing the carbs.
I've removed the 4 screws that hold the bowl on but it seems to be holding tight at the front edge of the carb.
Is there anything else that holds the fuel bowl on other than the 4 screws?
Joe
Re: Removing Float Bowl
« Reply #1 on: November 11, 2011, 11:18:15 AM »
No.... It's just stuck due to the rubber o-ring type gasket; gently tap it with a small hammer to break the gasket bond.
« Reply #2 on: November 12, 2011, 12:46:02 PM »
this has been covered many times before, but I do have to ask: exactly what or better yet how, are you expecting to complete this repair with the carb in place....upside down, standing on your head, in the dark recess up in there, blindly....and what transpires with the other 3 carbs, that are likely in no discernably better condition, just have'nt givin outward failure symptoms yet?
I highly suggest pulling them, and doing it right. :-[
all 4 of them.... you are only fixing this 25% by the attempt, and are setting yourself up for a soon to be further saga.
Offline turbojoe78
« Reply #3 on: November 13, 2011, 02:49:00 PM »
Here is the further saga, as posted on the "other" site
Rich your right ... trying to fix one float needle out of four, while still on the bike almost got me a broken fuel bowl.  Even when standing on my head and looking upside down, when I THOUGHT I had removed all four float bowl screws, I had in fact only removed three from the #4 bowl, and one from the #3 bowl.
I found this out after I pulled the carb bank out so I could look at it standing on my feet.  (after I had done quite a bit of prying with small screw drivers trying to get the bowl with only three screws removed off)
I also know that as stated by two people who know lots more than me about carbs, (Rich and Steve) that I was trying to take a short cut that was more than likely not going to work.  What I was hoping to accomplish was to get the #4 carb to stop leaking for the next couple of weeks, just to finish off my riding season.
What I found when I got it apart (after having to pull all the carbs out as Rich had suggested) was that the float needle rubber tip was deformed and more than likely the reason it was leaking.  (as Steve had said in one of his posts)
Anyway, it didn't work. I got it all back together and it still leaks after about 20 to 30 seconds of idleing.  I spoke with Steve this morning and told him what I had found and where I would go from here. (I had called him first before I even posted on the forum but he was unavailable)
I'm going to run the bike just one more time to do an oil change (do you want to know what oil I'm going to use??? lol) and then I'll pull the carbs off again and over the winter I'll get new float needles from Murph, polish the needle seats, make sure the pilot jets and idle passages are clean, set the fuel levels then drain everything and put them away for the winter.
I would like to thank everyone who tried to help me with this and if there's anything else you can think of that I should be doing, feel free to let me know.
Thanks Joe
« Reply #4 on: November 13, 2011, 03:05:04 PM »
Joe,
you are clearly more wise from the experience now, and I am sad there was such a hub-bub on the other site from the peanut gallary when Steve and i issued caution. I am however glad you did find the culpret, and are well on the way for getting it fixed, I think you will agree sometimes shortcuts aren't really short. Steve and I really do try to prevent others from having unsuccessful repair experiences, and we if anyone know how frustrating it can be attacking these things for the first time.
Best wishes, and success in curing the problem.
Offline dvitous
« Reply #5 on: November 15, 2011, 07:53:02 AM »
I had a leaky #4 as well... after a cleaning no less!
I did an in-place fix that corrected the leaking float valve, but I still didn't think it was running right,  ultimately ended up pulling the whole rack again last spring, and performing a much-more meticulous clean.
Reviewed all the carb clean/rebuild documentation, posts, etc. and went at it again.  Did a "bench synch" this time before re-installing, and had a much easier time with the running synch.  Much better results this time around.
Dan Vitous
Naperville, IL
Offline Mettler1
« Reply #6 on: November 15, 2011, 05:16:33 PM »
    This is what I like to see. Some one that looked for and found the info needed from the forum to complete the task at hand. Nice job!!    I found the "bench sync" very close and a sync gauge to get it right on after install. My '94 ran very good afterwards but now it runs great after Steve's 2MM + jets!
