Author Topic: Dry or Wet storage??  (Read 2550 times)
Offline WiConnie
« on: November 04, 2011, 02:13:11 PM »
Hey Guys,
Just got my tank back from being lined so it is totally fuel (and rust) free. Also cleaned my carbs while the tank was off so I have a completely dry fuel system...
I've always stored my bikes with a full tank of treated fuel and never had any spring time problems....I feel there is an advantage to keeping the carbs (float valve) wet.
Soooooo, should I fill the tank and carbs with treated fuel and go with the system I'm familiar with or leave em dry over the winter? Bike is stored in a Wisconsin unheated garage.
Thanks...
Barry
New to me 97
Germantown, WI
Re: Dry or Wet storage??
« Reply #1 on: November 04, 2011, 04:03:44 PM »
In your case as described as totally dry.... I'd keep it that way till spring.
Offline vinny
« Reply #2 on: November 06, 2011, 05:13:14 AM »
As Tony said - if its Ok dry now - keep it that way.  :)
Offline Raycad
« Reply #3 on: November 06, 2011, 05:51:41 PM »
....but drain the carb bowls to prevent gummy deposits from evaporation....
Ray
Raymond Cadieux, Québec, Canada - 2005 Concours
« Reply #4 on: November 06, 2011, 06:34:06 PM »
Ray
Put your glasses on..... He said the tank and carbs are completely dry.
Offline datsaxman@hotmail.com
« Reply #5 on: November 07, 2011, 02:53:41 PM »
Dry...but only because the tank is lined.
Dry clean steel tank would rust in the winter.
"Keeping the stuff wet" only helps once it is wet.  You have new parts in there, and they will stay new over the Winter.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
Offline WiConnie
« Reply #6 on: November 07, 2011, 05:28:12 PM »
saxman
I agree.
I have found in the past with my 1100F Honda that if I drained the bowls over the winter the float valves would leak in the spring. If I left the bowls full and occasionally turned the petcock on over the winter to keep the bowls full I wouldn't experience any leaking.
New to me 97
Germantown, WI
