Author Topic: Foamed oil?  (Read 9608 times)
Offline goatmar
  • Go where God wants you.
Foamed oil?
« on: October 13, 2011, 05:14:39 PM »
Okay all here's the issue.  I was going to work on the express way, doing 70 for a while, which is about 4k on the tach there abouts.  My oil light blinked at me, came on then off then on then off.  I slowed down to about 60 and watched it.  It didn't come on again.  I got to work check my oil and level was good, oil was dirty.
On the way home same thing, 65/70 oil light blinks at me, get home change oil, fire up bike to 3/4 grand and check oil and it looked foamy.  Looks the color of those Kraft caramels, you couldn't see through it.  The oil I drained out was dirty but didn't see any antifreeze in it.  I check radiator by popping the cap and looks green as new.  No smoke, not running hotter then normal.  Any ideas?????  Oil I put in is what I had in before the Shell Rotella T6.  I haven't taken the bike on the road yet.
Dave Muzzey
COG#7957
'01 Connie "BLUE"
Offline Bmcush
Re: Foamed oil?
« Reply #1 on: October 13, 2011, 07:16:59 PM »
Is it possible the electrical connection is loose at the pressure sender?
Offline Leo
Re: Foamed oil?
« Reply #2 on: October 13, 2011, 08:04:15 PM »
It takes very little water/coolant to foam up oil.  The first thing I would do Is change the oil and filter with whatever you have used in the past that was ok.  Make sure to get the engine up to operating temperature for at least 1/2 hour, even if you have to ride with a cover taped over the radiator.  That should dry any condensate out of the crankcase. If things do not look good by then, I would suspect coolant leakage.  These bikes are not prone to head gasket failure unless they are overheated.  I would suspect the water pump seal.  Be sure to let us know what you find. Good Luck
Yep, still riding the old one
In Indiana, missing Texas
Offline Daytona_Mike
Re: Foamed oil?
« Reply #3 on: October 13, 2011, 09:31:58 PM »
That sure seems to be a symptom of a blown head gasket and maybe  you are leaking coolant into the oil.
 I seem to remember a test to look for. I think it was something to do with looking for  bubbles of air  coming out  at the fill tube  with the rad cap removed but I could be wrong.
I think it  was Sunny Steve who had  a person with the same symptoms your having and the bubble test  confirmed it.
Offline T Cro ®
Re: Foamed oil?
« Reply #4 on: October 14, 2011, 06:53:59 AM »
Are you sure that the oil level was not too high? As that will cause foaming and oil pressure fluctuations; we have 4 new style CAT diesels that will do the same thing if you put too much oil in them.... With the bike on the center stand and after having sat for 15 minutes the oil level should be no higher than 1/2 to 3/4 covering the sight glass window.
Oil that has water in it will generally be a milky color of brown.....
Tony P. Crochet
Offline roadrunner322
Re: Foamed oil?
« Reply #5 on: October 14, 2011, 04:28:03 PM »
Gasoline in the oil will also turn it brown.  I've seen this many years ago on my Dad's old old pickup when the fuel pump diaphragm failed and was leaking gas into the oil pan.  Check to make sure your carbs aren't overflowing.
Currently Own
1985 Kawasaki ZN700
Re: Foamed oil?
« Reply #6 on: October 14, 2011, 07:28:33 PM »
Very good point and a good possibility.
Do you have over flow tubes?  If you do not then you may very well  destroy your engine with a leaky  carb at any moment and you may have already done damage. I do not want to scare you but we see  a lot of them here. Do a search for  hydrolock.
It is such a simple inexpensive fix to prevent  major damage to a perfectly good engine.
Offline goatmar
Re: Foamed oil?
« Reply #7 on: October 23, 2011, 08:42:55 AM »
Here's the latest, I put about 700 miles on it no problems, last Friday oil light came on lightly and stayed on.  Not bright as no pressure, just lightly.  Started it up the next morning, light was off.  Changed the oil again........ black again.  This time pictures to help, I hope.
First right after filling it, second after running it for about a minute or so.  I believe my carbs are okay, don't smell gas in oil.  Coolant looks clean........
Dave Muzzey
COG#7957
'01 Connie "BLUE"
Offline Leo
Re: Foamed oil?
« Reply #8 on: October 23, 2011, 09:03:38 AM »
In your second picture, I would consider that normal on oil that is not fully warmed up.   If it is brown/grey and looks like whipped coffee fappe when the bike is at full temperature I would be concerned about other things getting in the oil.
Now, about that oil light problem.  The sender is in the oil pan on the left side of the engine.  Senders can go bad.  It is simply a switch that connects the wire to ground below a pressure point.   That system can also be fooled by that wire touching electrical ground at any other point.  I would disconnect it from the sensor and start inspecting it going all the way up to the backbone wiring harness.  Any pinch or chaffing will cause the dash light to illuminate.    If that checks out change the oil pressure sensor.  I really do not think you have an oil pressure problem. An engine does not have to have zero pressure very long before it locks up.
Several years ago I had one where I would get low oil pressure that would come and go.  Even with a test gauge screwed in, the pressure was erratic.  It turned out that the last owner was a big advocate of using LOTS of rtv sealer, and the oil pickup was full of the little balls of sealer.  When the balls of sealer would shift around, they would block almost all the oil flow.
Good Luck
Offline T Cro ®
Re: Foamed oil?
« Reply #9 on: October 23, 2011, 09:39:11 AM »
What do those pictures indacate? Is the first picture of the engine shut down and the 2nd one running? If so then your oil level is TOO high.... After sitting shut down on the center stand for a few minutes the oil level should be no higher than 3/4 of the window. As I've said previously if your oil level is too high that can allow the crankshaft to dip into the oil and whip the oil into a froth which will cause oil pressure issues.
Tony P. Crochet
Re: Foamed oil?
« Reply #10 on: October 23, 2011, 10:07:43 AM »
first picture clearly shows overfilled, and second shot shows what the "at rest level"  should be . I tend to agree with Tony, on the overfilled thing. It also appears in the photos the engine in this area looks "shiney and wet" with some fluid mist coating....often this occurs on an over fill, and soon the waterpump oil seal will be a leaker....bt-st many times ...
No mention of the oil filter type, I'll note that a blocked or defective filter, or one that is not capable of the task, will force the oil to be bypassed thru the relief valve, which will definatly cause oil foaming. If you are dumping more than 3 quarts and 6 oz. in there you are overfilling (when the oil was drained using both drain bolts, and a new filter installed...)
Offline goatmar
Re: Foamed oil?
« Reply #11 on: October 23, 2011, 11:58:28 AM »
For Tony and Blues, the first picture is just refilled.  Engine not started yet.  My bike ('01) calls for 3.7 liters, a gallon is 3.785 liters. That's a complete fill.  Second picture is after has run for about a minute of so, then turned off.
The oil filter I us is a Scott's stainless steel filter.  Just clean and reuse, it's great.
Dave Muzzey
COG#7957
'01 Connie "BLUE"
Offline goatmar
Re: Foamed oil?
« Reply #12 on: October 23, 2011, 12:00:21 PM »
Thanks guys, Leo I'll look at your suggestions.  The thing that puzzles me is that it will work fine for a few days maybe a week and then the oil light issue starts?????  Wouldn't that be an on going thing?
Dave Muzzey
COG#7957
'01 Connie "BLUE"
Offline SteveJ.
Re: Foamed oil?
« Reply #13 on: October 23, 2011, 01:53:22 PM »
A complete fill, 3.7 liters is for a completely empty engine, ie. just after having it torn completely down.The refill with filter change is 3 liters, I call 3 qts close enough. Your engine is .7 liter over full of oil if you put 3.7 in it after having pulled both drain plugs and the oil filter.
Get rid of that reusable filter, it's not great at anything except wearing out the engine faster. it will not filter out the smaller particles from the oil, causing accelerated wear.
America's Seaplane City
Offline T Cro ®
Re: Foamed oil?
« Reply #14 on: October 23, 2011, 02:51:19 PM »
Exactly from the book (s)
Capacity:
2.7 L (2.9 US qt) when filter is not removed.
3.0 L (3.2 US qt) when filter is replaced. (3 US qt + 6 ounce)
3.7 L (3.9 US qt) when engine is completely dry.
Level: Between the upper and lower levels.
Your engine is overfilled and your crankshaft counterweights are whipping the oil into a froth and causing both your oil pressure and milky color issues.
At to the metal screen oil filter they are worthless at filtering out combustion byproducts and will only catch larger particles. If they were any good they would be used by the engine manf. Another one of them fancy fishing lures that were designed to do but one thing, catch fisherman. The only place we use metal screen filters on board ship is on non- combustion applications such as gearboxes or hydraulic systems.
« Last Edit: October 23, 2011, 03:27:07 PM by T Cro ® »
Tony P. Crochet
Offline goatmar
Re: Foamed oil?
« Reply #15 on: October 23, 2011, 06:49:20 PM »
Thanks all will readjust to the above suggestions.
Dave Muzzey
COG#7957
'01 Connie "BLUE"
Offline T Cro ®
Re: Foamed oil?
« Reply #16 on: October 23, 2011, 07:29:38 PM »
Let us know the outcome!
Tony P. Crochet
Offline Leo
Re: Foamed oil?
« Reply #17 on: October 24, 2011, 06:18:07 AM »
Kind of a side note about the screen mesh oil filter.  I have the technical understanding to see how a paper mesh filter will trap finer particles.  I also have the real life experience of putting almost 100,000 miles on an old XS 650 Yamaha without doing any engine work.  That bike has no paper fliter, it only has a bronze screen (with a magnet) and a magnetic drain plug. The lack of a fine paper mesh filter never seemed to hurt the longevity of that engine, even though the ball bearing crank is supposed to be less forgiving than a plain hydro bearing crank.  With the bike and the cars, if I miss changing the filter, it really does not worry me.  If the oil is kept up to snuff, there is not much in the engine to plug the filter anyway.
Offline T Cro ®
Re: Foamed oil?
« Reply #18 on: October 24, 2011, 12:23:21 PM »
.... That bike has no paper filter, it only has a bronze screen (with a magnet) and a magnetic drain plug. The lack of a fine paper mesh filter never seemed to hurt the longevity of that engine, even though the ball bearing crank is supposed to be less forgiving than a plain hydro bearing crank.
Leo it is my understanding as a Mechanical Engineer that a Crankshaft supported by Ball Bearings is actually MORE forgiving to oil particulates than a Hydro Wedge or Plain Bearing Crank but the ball bearing are unable to support the HP produced by todays engines otherwise they would still be widely used today due to their lower overall friction.
Tony P. Crochet
Offline goatmar
Re: Foamed oil?
« Reply #19 on: October 24, 2011, 07:13:46 PM »
Okay here's the latest as of today..........  put 70 miles on the bike today without any issues.  I took out about a cup of oil seeing you guys say I have to much in there.   3.7 liters almost 4 qts....
My thought is, near the end of the week issues will developed AGAIN then I'll change the oil again and put in the correct amount. 3+ liters
I'll keep you all posted, thanks for following.
Dave
Dave Muzzey
COG#7957
'01 Connie "BLUE"
