Author Topic: rear radial tire choices  (Read 10953 times)
Offline tbunder
« on: September 13, 2011, 02:14:29 AM »
so if I did my research thoroughly, I find that only dunlop and avon make rear oem sized radial tires for the C10. is this correct? the sport radial oem dunlop; and the avon azaro. just trying to minimize choices for when I pull the trigger. seems all the rest are bias ply. correct me if I am wrong.
and if possible, would someone be willing to post some detailed pictures of a '94- C10 with the 110/80-18 front tire? I'd really like to see how it contrasts to the rear sidewall vs. the 120/70. thx
Re: rear radial tire choices
« Reply #1 on: September 13, 2011, 07:22:02 AM »
While I don't have pictures to show you what you would like to see; I'll try to paint you a verbal yet slightly exaggerated picture. The K-Series 120/70-18 when mounted on the 3.0" rim tends to take on a rounded yet triangular shape with only a narrow rolling strip of rubber in contact with the ground. While this will give the bike a faster sport-bike like turn in as when you lean the bike over it rolls over that edge and the weight falls over. This will give you fast turn in but a heavier return as you have to muscle the bike back up and over that ledge. When you install a 120/70 from other manf on the 3.0" rim it will be even further pinched as the 120/70 is best suited when installed on a 3.5" or 3.75" rim and while this works OK at best the tire is not giving you the profile it was designed to give. On the other hand when a 110/80 is installed on the 3.0" wide rim it will take on a very natural broad/wide and rounded profile much akin to a riding a softball as compared to riding a hardball; this is because the 110/80 was made to fit on a narrower rim. But keep in mind that 3.0" is listed as an acceptable rim width whereas the 3.0" rim is not listed as an acceptable width for the 120/70 at all. These differences are really very easy to see when you look at bikes with "properly" fitted rims and tires such as the ZRX/ZZR etc with a 120/70 mounted on a 3.5" rim. This is why many skilled riders will swear by the 110/80 in place of the 120/70 as they have found that the bike will roll freely from one side of the tire to the other without that abrupt transition in the middle or falling sensation.
Offline emjayw
« Reply #2 on: September 13, 2011, 08:13:54 AM »
Great information T Cro, but it has nothing to do with the question.  I'm running a bias ply Pirelli Rte 66 on the rear of my '01 and it works beautifully with the stock front tire.  I have over 3K on it, mostly highway and mountain roads and it shows minimal wear right now.  Mike in too hot TX
« Reply #3 on: September 13, 2011, 09:29:50 AM »
Considering that I've seen that the OP wants to stick with Radial tires front/rear and is having significant issues with making up his mind on which tires to purchase I'm trying within my ability to point out that the 110/80 fits the 3.0" rim very well and will even improve the handling of the Concours thus I believe that my information is very valid.
« Reply #4 on: September 13, 2011, 09:32:10 AM »
so if I did my research thoroughly, I find that only dunlop and avon make rear oem sized radial tires for the C10. is this correct? the sport radial oem dunlop; and the avon azaro....
That is correct; they are the ONLY manf that I know of that currently produce a 150/80-16R for the rear of the bike.
Offline gtr1000
« Reply #5 on: September 13, 2011, 11:54:50 AM »
+1  ;)
Now my opinion of the Route 66 - my 06 came with a brand new one fitted on the rear. Having always had many Azaros on the rear of my previous A5, I road the 06 home from the dealers, a total of 60 miles in the rain and on twisties and promptly threw the Rte 66 in the trash  :o. To me it was like riding on a rim with no tire fitted.
3k on it so far - you'll probably get another 50k out of it and it'll still look the same.
It was the only rear tire I reckon that I could have gone 10 times round the world and still not shown any signs of wear - are they made of concrete?  ::)
Paul OTP (near Windsor, GB).
06 C-10, 2009 to .....
A5 C-10, 2000 to 2009.
Offline redzgrider
« Reply #6 on: September 13, 2011, 06:32:24 PM »
I don't know, I found the ME-880 to be just as good as you describe the Route 66.
Offline SteveJ.
« Reply #7 on: September 13, 2011, 07:24:20 PM »
I currently have a 110/80zr Michelin PR3 on the front of my '99, with my last Pilot GT in the rear. I really like the way it handles, stability, wear(guessing 12-14000 miles), price($125 from Dennis Kirk) and ride comfort. Some folks have been running the Avon Venom in the back with a radial in front, and reporting  good results. I swore off Avons a few decades ago, I'm thinkin' I may have to un-swear them. I' will be using the PR3 up front until they quit making them.
YMMV.
America's Seaplane City
Offline tbunder
« Reply #8 on: September 14, 2011, 10:51:58 PM »
awesome reply, lots of valuable info. there. I have noticed my "triangle" tire and the center of the tire which sticks out since it's an oem dunlop replacement. If I do indeed end up keeping my '01, I will probably go with the 110 for the reasons you mention, but also because I think the sidewall will be taller which will make it look more in tune with the rear tire's taller sidewall.
I once had a 1990 ZX-6- the first year for it. Anyways, it came with a 120/60 up front and a 160/60 in the rear. the front tire had nearly no sidewall while the rear was a lot taller. I replaced the oem front with a 120/70 and it made the bike look better simply because of the sidewalls being closer in size. it's dumb I know, but it makes a difference aesthetically. and like you mention, it will make the bike easier to navigate thru slower turns.
Offline tbunder
« Reply #9 on: September 14, 2011, 10:53:12 PM »
thanks. ;)
« Reply #10 on: September 15, 2011, 08:05:00 AM »
Great; glad you found some value in tires 101....
Offline redzgrider
« Reply #11 on: September 22, 2011, 06:34:21 PM »
Looking for a new rear tire, have enjoyed the D205 in the past, but now find that it isn't available anywhere anymore, and is no longer listed on the Dunlop fitment guide. Dunlop still lists the K700, but that's bordering on ME-880 bad.
Looks like the Avon is the only radial in stock size now.
Offline CRocker
« Reply #12 on: September 22, 2011, 07:38:58 PM »
tbunder...didn't you sell your C10?  This would be only one of the things you no longer have to worry about...
'02 C-10
Offline 2dflier
« Reply #13 on: September 23, 2011, 09:40:47 PM »
tbunder I hope you don't mind me dropping in.
I'm seriously considering a C10 but also seriously spooked by rear tire choices going away and no matched sets.  So if Avon is the only radial rear what do you match it with up front?  Are you at all concerned about the 16's going away?
I'm running a pair of PR2's on a ZRX1100 that I love.  Great grip and at 5K miles only about half gone but I don't know if they'd be as good if not matched.
Thanks much
« Reply #14 on: September 24, 2011, 04:45:14 AM »
Bunder sold his C10 and has not returned since the 19th .
I've just checked the Dunlop website and still see both the K700 and D205 Radial listed in the 150/80-16R sizing so I've no clue as to why they have become so hard to find; and while it means nothing Dunlop says that they are committed to these OEM sizings. For many so long as there is the AVON Radial Storm to be had for the rear they will look no further and I don't see AVON dropping that tire either. Even if the 150/80-16 radial tire were to go away there will always be large selection of this size in Bias ply as will there be in the next up sizing the 160/80 as these tire sizes are much too popular to abandon.
As to not finding matched sets it really matter very little as long as the types of tires complement each other you will be fine; my only comment is to never mount a touring or cold compound in the front with a sport compound in the rear.
Also expand your search to include the 110/80-18 (a better fit in my opinion than the stock 120/70) for the front as well as the 130/80-18 bias and again you will never lack for selections.
Listen to the true old time voices here not the newbies and they will tell you that with a good set of bias tires many many of you would never know the difference; and the same can be said for the mixing of radial front and bias rear it works too dam good to dismiss.
OR you switch out your rims for 17" front and rear and never will you lack for a selection of tires.
Offline 2dflier
« Reply #15 on: September 24, 2011, 06:37:40 AM »
Many thanks T Cro.  Yes, we newbies tend to get a bit worked up don't we?  I found the 17" conversion threads which is reassuring as are the voices of reason.  I'm sure there are threads debating the merits and effects of size choice within the the freedom of 17" selections but that can wait for another day.  Today I need to bounce over to rick3foxes' "Getting ready to take the leap..." thread to see which of the local C10's he's looking at will be left.
« Reply #16 on: September 24, 2011, 06:51:34 AM »
Naw we are now content with a 120/70-17R in the front and as for the rear there is a 160/70-17R or 170/60-17R to which the 160 might give the bike lighter turn in while the 170 is short FAT and looks sic back there while making the bike a tad more straight line stable but raises the RPM a touch. I choose the later.
Offline Summit670
« Reply #17 on: September 24, 2011, 07:16:07 AM »
Didn't know the D205 was still being made for the rear in the 16" size.  I've used a few sets of those and liked them, but I do most of my riding on straight roads here in Nebraska.
Don't the manufacturers have to supply parts (maybe tires are different) for at least 10 years once production is stopped?  If the last year of the C10 is 2006, then 2017 is when I'd start worrying about tires. ?
Arctic Cat M8 163 rules
« Reply #18 on: September 24, 2011, 07:17:51 AM »
I saw it still listed on their website so I'm assuming that they are still making the bugger.
http://www.dunlopmotorcycle.com/tirecatalog_category.asp?id=7
Offline redzgrider
« Reply #19 on: September 24, 2011, 06:32:20 PM »
"Listen to the true old time voices here not the newbies and they will tell you that with a good set of bias tires many many of you would never know the difference"
Well, I tried the ME-880 back when many others called it the best thing since sliced bread, and found it had all the traction of Teflon on snot. I'm not thinking of trying another bias ply.
Interesting that Dunlop shows the D-205 on their OEM listing, but doesn't show it for the Concours in their fitment guide.
