Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
The Bike - C10
(Moderator:
George R. Young
soliciting tips for bevel drive seals change
« previous
next »
Print
Go Down
Author
Topic: soliciting tips for bevel drive seals change (Read 2475 times)
jworth
Arena
Full Member
on:
August 23, 2011, 08:22:43 PM »
I'm gearing up to change the seals associated with the bevel drive. I already have the set of seals that Murph sells. So how about some good pointers? Are there any particular gotchas I should be aware of? On what else might this be a good time to do some routine maintenance?
TIA
Jeremy
Logged
T Cro ®
Administrator
Sr. Member
Country:
Re: soliciting tips for bevel drive seals change
Reply #1 on:
August 23, 2011, 08:57:18 PM »
Best pointer I have is a question..... Do you have a Service Manual? If not get one; and either way use it! I did...
Logged
Tony P. Crochet
Steve in Sunny Fla
Full Member
Country:
Reply #2 on:
August 24, 2011, 08:45:27 AM »
use only the oem steel gasket. be sure to clean all surfaces properly, and a dab of rtv on the engine side at the case seam. Don't put anything on the gasket, it's factory coated. Everything else is pretty straightforward. HTH, steve
Logged
http://sites.google.com/site/shoodabenengineering/home
roadkoan
Arena
Jr. Member
Country:
Some are as the river, some are as the rocks.
Reply #3 on:
August 24, 2011, 10:58:15 AM »
1:Watch out for the tiny pin that holds the front end of your drive shaft to the back end of the B.G.C.
It has a tendency to pop out when you remove the drive shaft (nothing holding it in)
2:If you don't have the bobbed rear fender, you will need your center stand on a 2x4 or better to get the rear tire out.
3: On re-assembly don't tighten the four bolts on your final drive till you have your axle "bolt" in place
4: SISF is too humble to say it but, Now is the best time to consider the 7th gear conversion...
Not too bad a job. Took me about 8-9 hours including healthy B.S. time (did er at a COG event) No funny tools required 'cept maybe if you count an inch-pound torque wrench.
Good Luck!
Logged
'02 C-10
jworth
Arena
Full Member
Reply #4 on:
September 17, 2011, 01:30:39 PM »
I'm 1/2 way through this job. Decided it was a good time for a lunch break. I've decided I won't change the output shaft seals as I don't have the special tool and it's not leaking now. That means 3 seals/orings won't get changed. I have oil constantly weeping out of a passage along the bottom mating surface of the case. I hope that doesn't mess up the seal. It was interesting to find that the seal in my '04 is a fiber seal and the replacement is metal. I figure if there was a change at some point surely by '04 they'd be putting them in. I'm given to understand the metal seal is preferable. I'll let you know how it turns out in case there is anyone with absolutely no life who might actually be interested.
Logged
jworth
Arena
Full Member
Reply #5 on:
September 17, 2011, 08:14:58 PM »
Got it all done and took it for a test drive. So far so good. The only real complicating factor was that I pinched the water pipe o-ring and split it. Luckily I was able to find a pretty close replacement at O'Reilly's. It's holding, but I'll keep an eye on it.
Logged
Print
Go Up
« previous
next »
The Bike - C10
(Moderator:
George R. Young
