« Reply #2 on: August 14, 2011, 06:46:10 PM »
I think you should be OK with just cleaning them up if they look to be in good shape. That's all I did with mine and I ended up with about the same year/model calipers you have. The EBC equivalent pad number should be FA158. As Steve said, a set of HH will be good or even a set of kevlar/organic pads will be OK. I'm running a set of organic pads and they seem to work fine for me.
Logged
