Author Topic: Where and how did you mount you Stebel horn?  (Read 4468 times)
Offline m hanlen
« on: August 13, 2011, 07:43:20 AM »
Where and how did you mount you Stebel horn? Got any pictures of it?
Offline Pfloydgad
Re: Where and how did you mount you Stebel horn?
« Reply #1 on: August 13, 2011, 10:10:27 AM »
Mine is mounted on the triple tree, below the inst. cluster. I used Industrial Wire ties and wrapped them around the horn and both down tubes, I use the regular horn wiring and completly removed the horns from the fairing. The horn assy. faces down and forward, and it does more then an adiquite job in getting attention.
Pics, well if I can get the camera down there, I'll try.
Hope this helps, ride safe.
Greg
Offline SteveJ.
« Reply #2 on: August 13, 2011, 05:36:24 PM »
I mounted my Freeway Blasters in the same general area, I used the metal strips that came with them to mount to the unused front brake splitter mount threaded holes
America's Seaplane City
Offline m hanlen
« Reply #3 on: August 14, 2011, 12:21:12 PM »
Greg
I must be holding my mouth wrong! Did you strip the front end to get it in there? I've tried about every place I can except the outside of the faring. I would like to mount it on the triple tree. Just need a better mind than I've got. Please send a pic if you can.
Offline Pfloydgad
« Reply #4 on: August 14, 2011, 02:21:08 PM »
Here you go M,
It is mounted to the triple tree and it moves with the steering. No I didn't take off the fairing to do it, but I did sacrifice some skin and blood in the process.
Good luck and ride safe.
Greg
Offline m hanlen
« Reply #5 on: August 14, 2011, 04:46:57 PM »
Well now, I thought I was pretty smart but couldn't figure it out. You're a better man than me. Looks like I have to "get 'er done". Thanks for the pics. I would have never believed it.
Offline Pfloydgad
« Reply #6 on: August 14, 2011, 07:58:33 PM »
That's what we are all here for.
Watch those knuckles.   :o
Ride safe all, and ATGATT.
Greg
Offline m hanlen
« Reply #7 on: August 15, 2011, 03:44:47 PM »
"Got 'er done". It fit but my finger tips are gone.
Offline KenE
« Reply #8 on: August 15, 2011, 05:47:15 PM »
Thot 1-I mounted the strebel nautilas under the seat where the rear air shock plumbing used to be. It is zip tied into a tupperware box, and then ziptied to the frame. AND:
Thot 2- strebel makes a LOUD horn (sold by Murphs) that fits right in the old horn placement... Really LOUD- esp now with both horns going.
Both run off the same separate relay...
HTH
KenE
Offline Pfloydgad
« Reply #9 on: August 15, 2011, 08:55:51 PM »
Good job M, your sacrafice will be worth it when you hit that horn next to a texter. Glorious.  :thumbs:
Ride safe all, and ATGATT please.
Greg
Offline m hanlen
« Reply #10 on: August 16, 2011, 10:30:58 AM »
OK, I give up. What's 'ATGATT" mean?
Inquiring minds want to know!
Offline Outback_Jon
« Reply #11 on: August 16, 2011, 02:53:56 PM »
All The Gear, All The Time.
Offline blade
« Reply #12 on: August 16, 2011, 09:10:51 PM »
I seem to recall someone on the old forum split the Steibel and put the compressor portion in the fairing near the glove box and then ran a longer airline to the horn section attached to the triples/splitter area. Maybe someone else can remember the details or have done it themselves.
« Reply #13 on: August 16, 2011, 09:22:08 PM »
Lights - Camera - Action
Well almost !!! We gots lots of light and lots of loud here; as the stock horns are still in their OE home plus these Blasters mounted down below.
Offline m hanlen
« Reply #14 on: August 16, 2011, 10:57:59 PM »
That's a good idea. I like it. I like your rotors more!
Probably would have been easier than mounting the Stebel Nautilus horn.
