Author Topic: Oil light question  (Read 2281 times)
Offline F-106
Oil light question
« on: August 11, 2011, 10:01:30 PM »
Is it normal for the oil light to take a bit longer to go out after you restart the bike within 3-5 seconds of shutting it off. I rode home today and put the bike in the garage. I shut her down and then went for restart. I noticed the oil light took 1-2 sec to go out. I have noticed this now twice in the last few days. In the mornings after sitting overnight the light goes out almost before I get the starter button released. The bikes oil level is good and is running fine. The bikes an 06 with 10,700 miles .....thanks
IN THRUST WE TRUST
Re: Oil light question
« Reply #1 on: August 11, 2011, 10:24:08 PM »
Hot oil gets thin, thin oil creates less pressure than cold thick oil thus it could take a moment or two longer to build oil pressure when restarting a hot engine.
Offline Ron Moss
« Reply #2 on: August 12, 2011, 06:54:54 PM »
Don't want to alarm you but my '06 starting having problems with the oil light coming on during hard braking. It kept getting worse and would get to the point I lost all oil pressure. (checked with an oil pressure gauge) After trying every thing I could think of I replaced the oil pump. 3700 miles later and no pressure problems. I keep reading about 2006's with oil related problems. I would keep an eye on it. Hope your bike has a long trouble free life.
Offline F-106
« Reply #3 on: August 12, 2011, 08:01:55 PM »
Thanks, I hope it does not get to the point of a pump change. However, you never know. Modern day bikes should not have problems like that. I will do an oil change tomorrow and see what happens. My problem is on a hot start not braking, I hope your 06 remains trouble free.
IN THRUST WE TRUST
Offline F-106
« Reply #4 on: August 12, 2011, 08:11:47 PM »
Thanks for your reply. I am still getting use to the connie and it does behave differantly than my valkyrie did. It may just be the way this bike is this may be something I need to get use to seeing.
IN THRUST WE TRUST
