Author Topic: where to buy pickup coil?  (Read 3824 times)
Offline Silver Connie
« on: August 04, 2011, 09:09:56 AM »
i need a pu coil. all my searches lead to ebay junk. lookin for a new one but cant find anything. these still available?
Offline midnightrider
Re: where to buy pickup coil?
« Reply #1 on: August 04, 2011, 09:12:37 AM »
None on ebay? Try here http://www.ronayers.com/ use the microfiche lookup for stock parts.
2004 C10 RIP
Offline Summit670
« Reply #2 on: August 04, 2011, 10:58:56 AM »
Cheapcycleparts.com
I checked there but bought from local dealer because they matched price and had quicker shipping.  Like $115.
Arctic Cat M8 163 rules
« Reply #4 on: August 04, 2011, 04:34:35 PM »
thanks but not lookin for ebay junk.
Offline Summit670
« Reply #5 on: August 04, 2011, 09:18:27 PM »
Tonight I took a hammer to the old pickups.  Not much to fail inside those things, man they are solid, no moving parts that I could see.
What happened to me is one of the wires going into the pickup had worked loose over the years (1987 model) and when I started to take the coil apart (hacksaw) one wire more or less just fell out of where it goes into the pickup.  The other wire took some force to remove/break it.
« Reply #6 on: August 04, 2011, 09:39:42 PM »
yeh didnt look like much. maybe i could cut them apart and resolder. is it common for oil to be in that housing? when i removed the inspection cover about a teaspoon of oil ran out.
Offline Mettler1
« Reply #7 on: August 04, 2011, 10:38:33 PM »
« Reply #8 on: August 05, 2011, 05:19:15 AM »
.... is it common for oil to be in that housing? when i removed the inspection cover about a teaspoon of oil ran out.
Yes.... See that little chain thingie? That's the cam chain it's connected to the camshafts and they run in oil.
