Author Topic: bike lowering  (Read 8289 times)
Offline Ghost Rider 2
bike lowering
« on: July 24, 2011, 06:52:46 AM »
  Looking to buy a Concours for my wife.  bike is a little to tall for her.   She has riden my 04 but is not comfortable.  did a search for lowering kits and came up with 1400 stuff only.  Is there a kit or what is the best way to drop a ZG1000 a couple of inches and not mess the handleing up.  Thanks.
Offline mlf73
Re: bike lowering
« Reply #1 on: July 24, 2011, 08:12:47 AM »
Norm Soucy is the gentleman who makes and sells lowering links for the C10.  His email is sanleonster@gmail.com and phone number is 281-339-1156.  I can't recall if he has a website or not.  I have one of his lowering links on my bike due to the increased ride height after installing a C14 shock.  I think he has 3 different sizes for the C10.  You should be able to drop the front end by raising the forks in the triple tree clamps if necessary.  I'm sure there will be more feedback shortly.
Offline jim snyder
Re: bike lowering
« Reply #2 on: July 24, 2011, 08:24:50 AM »
mlf73 gave you what you need. Call Norm and see if he has any links. I have had mine lowered for almost 4 years now and its great.
Re: bike lowering
« Reply #3 on: July 24, 2011, 08:59:00 AM »
   Sent an email.  Sounds like the person I need to talk to.
Offline DarkKnight
Re: bike lowering
« Reply #4 on: July 24, 2011, 12:23:05 PM »
I lower a full 2" and once I altered the center stand, I have no issues cornering.
Offline oldsmoboat
Re: bike lowering
« Reply #5 on: July 24, 2011, 01:15:23 PM »
I talked with Norm but don't have the equipment/skills to cut down the stands.
Offline Uglydog56
Re: bike lowering
« Reply #6 on: July 25, 2011, 09:52:11 AM »
My center stand doesn't grind unless I'm 2 up, and you have to be leaned over pretty far.  Also - it's a self-correcting problem - eventually the feet will be triangle shaped and quit grinding.  ;)
Rick A. Cone
COG #9186
98 Connie, 76 CB400F
Offline elvin315
  • Global Moderator
Re: bike lowering
« Reply #7 on: July 25, 2011, 04:32:37 PM »
All you need to know about getting your feet closer to the ground is in the FAQ. From sculpting your seat to lowering the frame
http://www.zggtr.org/index.php?topic=578.0
