Author Topic: battery water check  (Read 2428 times)
Offline mjrfd99
battery water check
« on: July 21, 2011, 06:18:43 AM »
  FYI---Did mine this am- low needed a fair amount.  This heat wave seems to require more checks and top off.
Offline snarf
Re: battery water check
« Reply #1 on: July 21, 2011, 06:26:28 AM »
Thanks for the reminder, that is the most common thing I over-look
2002 Conc
1986 Conc "The spirit of COG"
Offline Outback_Jon
« Reply #2 on: July 21, 2011, 06:29:44 AM »
+1  Mostly cause it is such a PITA to pull the battery.  That's why I got a sealed AGM this year.  I kept finding I had about an inch of liquid in the battery by the time I remembered to check it.  I figured after abusing it like that for 5 seasons, it was time to get a new battery just to play it safe.
Offline Summit670
« Reply #3 on: July 24, 2011, 07:45:53 PM »
If you use the "maintenance type", take a black fine tip marker and draw lines on the battery where there are no lines so you are more apt to be able to see the water level without pulling the battery.
Arctic Cat M8 163 rules
Offline mjrfd99
« Reply #4 on: July 25, 2011, 06:25:29 AM »
On the C-10 I dont put the screws in the tool tray. I dont disconnect battery -just pull the battery caps.  A blue baby snot sucker is how i add and level water- when stuck in to correct depth it will fill then suck the over fill out.
Battery tender and correct water level will extend battery life IMHO
I add acid the first time I top off a new battery.
My 05 is still on the original battery. Now you know it'll die tomorrow ::)
