Author Topic: Temp gauge  (Read 2388 times)
Offline Ron Moss
Temp gauge
« on: July 16, 2011, 07:41:36 AM »
My temp gauge developed a strange problem. It works just fine but it reads cooler than it used to. It looked like what has happened is that the pointer has slipped on the shaft. Before I try anything I thought I would ask if anyone knew if you could get into the gauge to adjust the pointer with out to much trouble. No other problems just reads low. When ign is shut off the pointer is well to the left of the white square compared to where it used to be. Any thoughts??
