Author Topic: Mounting Sena SMH10  (Read 3858 times)
Offline Awaz
Mounting Sena SMH10
« on: July 14, 2011, 01:42:05 PM »
My helmet got two ridges running along side the chin bar. This makes mounting the Sena bit hard - at least it does not go flush against the helmet. Wondering if you guys got any idea to circumvent this issue.
2016 Ducati Scrambler
2008 C14
Re: Mounting Sena SMH10
« Reply #1 on: July 14, 2011, 01:54:09 PM »
Pictures would help, but I would say that mine doesn't  appear to fit perfectly flush with the helmet. Sena had this in mind I'm sure when they built the system.
Offline TRBN
« Reply #2 on: July 14, 2011, 07:06:15 PM »
My Sena does not fit flush against the helmet either.  It is not going anywhere...
My helmet is the Shoei Qwest.
Aaron
« Reply #3 on: July 14, 2011, 07:15:54 PM »
You could try the two sided tape mount w/o the clamp, clean the area with de-greaser and it will hold fine.
« Reply #4 on: July 15, 2011, 04:24:38 AM »
I tried the tape, with a degreaser, and it fell off on the first ride.  I decided to use the mechanical route.  The only thing I had to do was cut off a bit of the plastic lip on my Scorpion helmet.  Snug as a bug in a rug.
Offline COGnosticat0r
« Reply #5 on: July 15, 2011, 10:27:09 AM »
 :yikes:  Maybe it was the degreaser that did it.  I used alcohol and my stick on has been on the helmet for 10k miles at speeds up to 130 and rain and sun and still strong.  Mine is a Shoei multitec.
Jerry Holland
COG 4478
2013 C14
« Reply #6 on: July 15, 2011, 10:52:58 AM »
Gorilla Glue makes velcro that holds nicely.
« Reply #7 on: July 15, 2011, 11:01:52 AM »
3M VHB. It's in the automotive section. Commonly used for applying trim and decals to vehicles.
« Reply #8 on: July 15, 2011, 01:15:54 PM »
Thats what I used, guess I should have used the correct words.
Offline cablebandit
« Reply #9 on: July 15, 2011, 06:54:19 PM »
Mine clamped on my Multitec just fine.  Using both generations of clamps.
Offline Awaz
« Reply #10 on: July 16, 2011, 03:31:11 PM »
Sorry, have not got around to taking a picture. There is a big gap in the top of the mounting bracket. But it appears using the screws to mount, it is pretty snug. Guess I will not worry about it.
2008 C14
