It's a semi-bolt on affair that required some shade tree ingenuity to mount the ZG oil cooler, aftermarket GPz radiator, and securing the rear undertray. Basically the oil cooler lines are a tad short so it goes behind the lower frame mount with longer bolts serving as studs. AliExpress radiator needed two .5 inch rubber bushings, longer bolts & nuts, and a trick to get in there because the end tanks will interfere with the frame. I couldn't find a GPz lower tray frame that goes under the engine so again thick bushings & longer bolts to the oil pan worked out. The windscreen is an AliExpress part, it's a sport touring style slightly taller.
I didn't keep track of cost, you know how these things add up.
It probably would have been better to just buy a GPz900 but wrenching on bikes and cars are a hobby of mine. Keeps me sane.
Here's my 1986 GL1200.
