Author Topic: Finished ZG1000 restomod  (Read 3272 times)
Offline Chrome Megaphone
« on: March 02, 2022, 08:20:29 PM »
I finally got it finished, took two years and a lot of advice and inspiration.  Thanks for the how-to threads, especially the ZRX1100 2mm overbore article.  With that and GPz carbs and cams it really comes on strong in the mid-range.  The OEM saddle bags were just too far gone with holes and such, I think these smaller ones blend nicely with the GPz900 fairing.
Offline DC Concours
  • 2001 Concours, ~35K miles
Re: Finished ZG1000 restomod
« Reply #1 on: March 02, 2022, 09:20:33 PM »
Congrats. Looks beautiful. Must feel great to be done. Post a video if you have one.
« Reply #2 on: March 03, 2022, 03:57:03 AM »
Nice GPzG1100 ;D
Where didja put the oil cooler? I can't see it in the pics.
Offline Stasch
« Reply #3 on: March 03, 2022, 07:09:10 AM »
Looks great!
Any chance for additional pics?  I would like to see how you fabricated the saddlebag mounts.
Did you go with the GPZ900 radiator to fit into the fairing?
« Reply #4 on: March 03, 2022, 08:29:45 AM »
Nice GPzG1100 ;D
I've been wondering what phantom model it is now 🤔 ZG1100X? GPz1100SD (shaft drive)...
I'm waiting on a shipment of oil filters to change out the break-in oil so no high speed video yet.  Here is a test video, third start about an hour total run time
https://streamable.com/whl0c9
Offline DC Concours
« Reply #5 on: March 03, 2022, 08:53:37 AM »
Nice crisp response. What's your idling RPM there?
« Reply #6 on: March 03, 2022, 09:04:52 AM »
800 rpm give or take.
« Reply #7 on: March 03, 2022, 09:09:32 AM »
Looks great!
The radiator is a Chinese GPz900 unit from AliExpress, it is so efficient the cooling fan doesn't turn on in city driving only when I stop. The fan sensors are different between the GPz and ZG, the latter is a two prong.  I gave up trying to make it work and installed an adjustable sensor switch taping the capillary prong thingie on top of the radiator with high quality aluminum tape.  Radiator was a pain to install though because it is a bit fatter, and the ZG coolant pipes aren't exact to the GPz  it took shimming and cutting hoses and 10 cups of coffee.  The oil cooler is original you can't see it because it is painted semi-gloss black.  That fit with trimming the lower tab, drilling through the welded nuts, hardware store bolts & washers, and reversing the mounting location.
TBH while doable these mods took up a great deal of time.
These are the saddlebage, while half as large as ZG bags losing the entire OE saddlebag framework was a HUGE weight savings. The new angle iron mounts were cut down and trimmed to fit on pre-existing threaded holes, brake rotor bolts with washers to adjust made it work.  Since the new bags are universal you have drill them and on one side I had to drill over again and fiberglass the mistake holes (uneven) because there was no one around to hold them up while marking the locations.
Hope this helps
https://www.ebay.com/itm/185040941421
« Reply #8 on: March 03, 2022, 09:11:48 AM »
Saddlebag mounting.
If someone needs the ZG panniers I can post pics in another thread.
Offline m in sc
    • 2 stroke world
« Reply #9 on: March 04, 2022, 04:38:48 AM »
yeah man, I like that a lot, looks great. well done.  8)
« Reply #10 on: March 05, 2022, 02:05:12 AM »
If you follow the Kawasaki branding then it should be a GPzG1100ST but it could also be a Kawasaki Concourz 1100.  ;D
