Author Topic: Mobil 1 0W-40 European Car Formula Advanced Full Synthetic?  (Read 2816 times)
Offline Pilgrim
  • '12 Black
« on: November 05, 2021, 06:25:40 AM »
Has anyone used this in their bike?  Would you use this in your bike?
Re: Mobil 1 0W-40 European Car Formula Advanced Full Synthetic?
« Reply #1 on: November 05, 2021, 10:09:44 AM »
I wouldn't as the first number is the cold viscosity and our engines are designed for 10W40.
0W40 is going to be thinner at all temperatures and may not lubricate correctly.
Offline Daytona_Mike
« Reply #2 on: November 05, 2021, 11:24:57 AM »
I do not think you can use this in our motorcycles. I do not see anything saying 'Friction Modifiers' but then again I do not see the correct API spec (JASO)   The above's   Mobil 1  API Rating:   SJ,SN,CF,SM,SL
 Requirements for ZG1000 Concours:    API SE, SF, or SG; or API SH or SJ with JASO MA
 Requirement for  ZG1400  Concours:   SAE 10W-40 engine oil with API SG, SH, SJ, SL or SM with JASO MA, MA1 or MA2 rating
So ,  bottom line.. I do see SJ  so it MIGHT work... but why chance if it doesn't?  I always look for the JASO-MA rating. If I do not see it ... then I do not put it in my Concours (plural)
« Reply #3 on: November 05, 2021, 01:49:13 PM »
I wouldn't use it in a motorcycle.  I'd use Mobil 1 10w-40 4T.
Offline Pilgrim
  • '12 Black
« Reply #4 on: June 23, 2022, 10:23:16 AM »
I did use it and have gone thousands of miles with no problems.  The bike doesn't mind one bit.
Noticed less clatter at cold starts.    I could not tell or feel any difference in engine operation or performance.
I'll let you know if it blows up before the next oil change.   :)
Offline DC Concours
  • 2001 Concours, ~35K miles
« Reply #5 on: June 23, 2022, 12:42:43 PM »
Aren't these oils more expensive than the cheaper 10W-40 that are designed for the motorcycle?
Offline Pilgrim
  • '12 Black
« Reply #6 on: June 24, 2022, 05:27:31 AM »
Six months ago, I paid $23 for the 5-quart container.
