Author Topic: Help, C10 wont crank  (Read 1903 times)
gpineau
« on: July 07, 2021, 12:07:11 PM »
Yesterday I went out to start my connie and it turned over one rev then stopped.  Further pressing on the started button just gave me a click.  I though it may be the battery so I went and got my starter battery which is fully charged. No -go. It just clicks. It's not hydro locked because it dont have carbs. It's fuel injected.  Just guessing but maybe the starter chain broke?
Any guesses?
Offline m in sc
    • 2 stroke world
Re: Help, C10 wont crank
« Reply #1 on: July 07, 2021, 12:16:48 PM »
if the chain broke id imagine the motor would still spin. have you tried jumping the contacts on the starter relay? just because it clicks doesn't mean its good.
« Reply #2 on: July 07, 2021, 02:16:17 PM »
A dirty side stand switch would prevent it from trying to start.
Offline m in sc
    • 2 stroke world
« Reply #3 on: July 07, 2021, 03:28:24 PM »
solenoid wouldn't click though.  .02
Offline Daytona_Mike
« Reply #4 on: July 07, 2021, 08:18:37 PM »
Dirty starter solenoid will click but not conduct any voltage to run the starter. Easy to verify and diagnose and easy to take apart to clean the contacts
« Reply #5 on: July 08, 2021, 06:31:02 AM »
The C10 starter motor drives the alternator shaft via a centrifugal clutch.
The alternator shaft then turns the crankshaft via the alternator chain when starting the engine.
If the tensioner for the alternator chain breaks, it can jam against the clutch basket preventing starting.
Easy enough to check. Just gotta remove the clutch cover.
« Reply #6 on: July 08, 2021, 08:15:59 AM »
We didn't think of the most obvious.
Are the Battery leads clean and tight?
gpineau
« Reply #7 on: July 08, 2021, 11:11:31 AM »
I'm regretting that I ever bought this bike.
I'll short the solenoid and see if the starter turns.
 If the fails I will pull the clutch cover. Any chance of reusing the gasket?
« Last Edit: July 08, 2021, 12:35:42 PM by gpineau »
gpineau
« Reply #8 on: July 08, 2021, 11:25:28 AM »
Im in luck , I think. I stuck s screw driver across the solenoid, big spark. Now it starts every time.
Offline m in sc
    • 2 stroke world
« Reply #9 on: July 08, 2021, 01:53:23 PM »
yup. a new solenoid would be a good idea at this point.
« Reply #10 on: July 09, 2021, 01:55:29 AM »
I've reused mine many times and no leaks.
I just smear a thin layer of Blue Hylomar on it and bolt it up.
Glad you got it sorted.
Yup, new Solenoid needed.
They are horribly expensive though  :rotflmao:
https://www.ebay.com/itm/363327143252
gpineau
« Reply #11 on: July 09, 2021, 12:29:45 PM »
I'll order one today just incase it happens again.
Finally got all 4 of my bikes running.
Two connies on the right are both converted to fuel injection, the Yamaha came that way from the factory. The Honda on the far left is still carbureted at least for a while.  I am going to move the naked one to the garage and update it with all the software improvements that I made on the last one.
Wife said 2 of these got to go but I don't know which ones to keep!
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #12 on: July 09, 2021, 01:15:06 PM »
One of those that you keep had better be the wife. LOL
gpineau
« Reply #13 on: July 09, 2021, 01:27:02 PM »
No debate there. Wife is a keeper.
I want to keep one of my Connies. Probably the naked one that has been chopped down. It's the oldest one but I like driving it because I have lowered it and put pull back riser and a honda handle bars.
I wont give up my yamaha either. Its the youngest one and I also enjoy riding it on long trips.
The little honda magna is a real kick to drive. Its got too much HO for a small bike.  I just got it, fixed it up and made it all pretty but I guess I will let it go too.
So its the little Honda magna 750 and the 1999 C10 up for sale this weekend. If anyone wants to take over the Connie I have all the parts to return it to stock if you are afraid of the EFI changes I made.
Ordered a replacement for the starter relay.  https://www.amazon.com/dp/B078S7BJ8V?psc=1&smid=A1GSUR6QOCZ9BO&ref_=chk_typ_imgToDp
gpineau
« Reply #14 on: July 12, 2021, 09:58:13 AM »
Went to install the new starter relay and found the real problem. The nut holding the positive lead from the battery was loose and corroded.  I could wiggle it and make intermittent contact.  So i have an extra relay for some future project.
« Reply #15 on: July 12, 2021, 12:35:26 PM »
I have never seen a C10 starter  relay go bad. The contacts will get dirty or corrode.. take it apart and clean it.
No need to replace it. I tried to tell you this earlier but maybe i wasn't clear enough.
Glad you found the real problem.
Offline m in sc
    • 2 stroke world
« Reply #16 on: July 14, 2021, 01:54:48 PM »
ive had one go bad in a CB750 wayyy back. overall its rare but it can happen. just .02. glad it was an easy fix.
« Reply #17 on: July 14, 2021, 04:32:13 PM »
See Reply #7...
