Author Topic: 2002 C10 Silver possibly for sale - $2750  (Read 760 times)
Offline mlf73
« on: April 28, 2021, 06:37:15 AM »
UPDATE:  I was going to delete this post but I'm not allowed.  Therefore, it stays.  Probably just going to take the bike with me unless someone shows up later and is really interested in the bike.  Thanks.
Not sure I want to do this but I'll put it out there and see if there is any interest.  I'm preparing to relocate cross country and taking very little with me.  Currently located in the Raleigh, NC area.
I'm the 2nd owner of this bike and it currently has 50.7K miles.  It's in pretty good shape and runs pretty well with no issues.  I've done quite a bit to it in the 14 or so years I've had it.  I'll try to list as many as I can.  Most are listed in my signature as well.  I'll update the list below when I have move time.  Other pics are available.  Hopefully the 4 I attached with show up.
Tires are almost new.
New EBC rear rotor.
Front brakes upgraded to 4-piston calipers and larger rotors.
Stainless brake lines in front.
Brakes are good but have new sets for front and rear when needed.
C-14 rear shock.
Sonic springs in front.
Motorcycle Larry fork brace.
Front Tip-over bars with highway pegs.
Lowering link.
Bar Risers.
Stick coils.
HID headlight.
Murphs fuse block.
SISF's economy jet kit.
Givi trunk.
Heated grips.
Duel heat-troller with mounted controls.
Two 12 Volt outlet.
Cee Baileys vented blue tint windshield with a taller Cee Baileys for winter.
Corbin seat - still have stock seat as well.
Block off plates to remove smog crap.
New UNI air filter.
SPOOFAK - Spin on oil filter adapter.
RAM mounts for phone and GPS (can stay with bike).
HVMP bar ends.
Throttle lock (used to have Audiovox CC but servo died).
Fender extender on front - Rear fender bobbed.
Coolant overflow relocated under seat.
Helmet locks relocated by license plate holder.
« Last Edit: May 12, 2021, 09:17:18 AM by mlf73 »
Offline mlf73
Re: 2002 C10 Silver possibly for sale - $2750
« Reply #1 on: April 28, 2021, 09:09:59 AM »
A few more pics....
