Author Topic: Camshafts reset!  (Read 1175 times)
Offline jacksdad
Camshafts reset!
« on: March 27, 2021, 07:11:56 AM »
My camchain tensioner failed, luckily it happened whilst I was trying to get the carbs set up, so as soon as I heard the death rattle I hit the kill switch!
For some reason I struggled to get the chain to sit back on the exhaust cam sprocket, but I've finally got it rebuilt: do the sprockets look correct? I think they are, but the marks look slightly low?  :-[
gpineau
Re: Camshafts reset!
« Reply #1 on: March 27, 2021, 09:57:06 AM »
Have you watched Steve's video yet. It looks right but cant tell for sure without knowing where you crank is positioned.
https://youtu.be/NpeG93CqFPw
Offline jacksdad
« Reply #2 on: March 28, 2021, 12:52:10 PM »
Here is the sprockets when I removed the cover:
« Reply #3 on: March 29, 2021, 01:06:11 AM »
If the tensioner lets go, it is rare that the camchain slips, but it does make an ungodly racket.
With the timing plate on 1-4 TDC, the cam markings should be exactly as in this image, WITH the tensioner fitted and correctly tensioned.
I'll check for that carb part for you tonight Mike :-)
« Reply #4 on: March 29, 2021, 07:58:39 AM »
 :goodpost:
