Author Topic: Muzzy lowering link & bearings  (Read 1632 times)
Offline Chrome Megaphone
« on: October 05, 2020, 01:07:30 AM »
What am I supposed to do with this?
Re: Muzzy lowering link & bearings
« Reply #1 on: October 05, 2020, 01:09:27 AM »
I don't see how this is bushed.  Thanks for any advice, I hope this is the correct part.
« Reply #2 on: October 05, 2020, 07:38:56 AM »
It's not bushed.
The bearing inside the rocker is where the Linkage pivots.
Just bolt it on "gut-n-tite".
NOTE: Put the center-stand down / add a rope or other to hold it forwards / get a measurement from axle to somewhere (straight up) on the frame/ place the end of a 3'-4' board under the tire  (you can use it as a lever) / remove the bolts / use the lever to raise the wheel slightly and remove the Links / raise it more and install the Muzzy links / install and tighten the bolts / re measure from axle to (the same place) on the frame /.
"Mission Complete"
Lastly; Subtract the first measurement from the second measurement to determine the amount of drop (please report the numbers here).
« Reply #3 on: October 05, 2020, 07:44:08 AM »
STOP: Wait a minute!!
Something is wrong...
A Lowering Link should be "longer" than the OEM Link.
I just remembered that you have a C-10.
Your Muzzy Link appears to be off of a C-14 (or other).
« Reply #4 on: October 05, 2020, 08:19:31 AM »
Did an image search and you're right, C14  :(
« Reply #5 on: October 06, 2020, 08:49:26 AM »
A dick### from this forum who said he didn't know how to post images of what he had replied to my thread which stated C10 lowering links needed sold me C14 links.
gpineau
