Author Topic: Wiseco head gasket gripe  (Read 1302 times)
Offline Chrome Megaphone
« on: August 19, 2020, 06:53:09 PM »
I bought this expecting a Cometic shim steel coated gasket like the one that came with an earlier purchase. I could trim that if necessary, however this Victor Reinz garbage I can't.  When did Wiseco start going cheap with their overbore gaskets?
Re: Wiseco head gasket gripe
« Reply #1 on: August 19, 2020, 06:56:42 PM »
.01 clearance, I think once torqued that will close up.
Should I return it or install?  Piston shouldn't travel that far me thinks.
ZRX11 piston on ZX10 rod
Edited for typo
« Last Edit: August 20, 2020, 06:09:08 AM by Chrome Megaphone »
Offline turbojoe78
« Reply #2 on: August 20, 2020, 05:54:47 AM »
Wouldn't you want an overbore gasket for a ZX1000R?  The one you have shows you going to 972cc.  I believe when you go with the ZX1100 pistons it goes to 1052cc.
When I did the overbore with the ZX1100 pistons on my 99 C10, I used a new stock head gasket and opened it up some with a dremel till it was just bigger than the cylinder bore.
« Reply #3 on: August 20, 2020, 06:07:45 AM »
I did a typo, 1999 ZRX11 pistons, 1988 ZX10 rods, followed this
http://www.zggtr.org/index.php?topic=175.0
