Welcome Jason, so did you want us to all just unload everything we've done to our bikes or did you want to give us some of the problems you may have experienced on yours.
Most have had seat comfort issues as well as handle bar comfort issues. These all seem to be very subjective, so mostly the info from us will be about things to try as there doesn't seem to be any one fix for everybody. If you are experiencing any of this then I suggest that you find a solution to the handlebar issue before you search for a seat solution since the former may effect the latter more than the reverse. They are interrelated for sure. My solution was to raise and move the bars back a bit. I say a bit because I didn't have to get hose extensions for the clutch and brake lines, but I'm right at the limit of mine. My seat solution is an Airhawk seat pad. I just don't want to go through what others have had to do because going from one $400 seat to another $600 seat seems dumb when an Airhawk lets me ride 10+ hour days without my butt being the thing that hurts the most when I stop for the day.
There are of course, other things that can be modified. It's a darned heavy bike for some of us little guys so tip over protection can be important to protect the plastics. Some like an electronic cruise control, and more electrical outlets on the side for heated gear. Some move the under seat tools into the side case so they have room for an electrical distribution block under the seat, some want louder horns, aux lighting. Some pin the side bags so they don't fall off and others think that's just silly.
So Jason, I suggest that you get to know your bike by just reading the owner's manual to make sure you understand the ins and outs of Kipass, of the different fuel maps etc.
Seems a bit boring maybe, but there are a lot of misconceptions and misinformation out there that can be eliminated by simply reading the OM. Might I suggest you keep it in the bathroom for a few weeks until you find the time to go through it? Disregard this last suggestion if you are currently having toilet tissue supply issues.
So tell us more about your bike, used? new? ....if the former, any pre-installed farkles?
What is the first thing that you'd like to change about it if you had a magic wand?
Many of us are home bound so we've got nothing better to do than give you suggestions.
..again, welcome Jason.
