Author Topic: any ideas for my atv  (Read 3057 times)
Offline S.Ga.Rider
« on: July 07, 2011, 05:36:34 AM »
I have a 05 suzuki ltz250. I was riding the other day and it stated cutting out at small throttle openings, full throttle it runs fine. I figured one of the jets were clogged. Pulled the carb and sure enough their was. I cleaned it, put it back together and the same thing happened. I ordered a rebuild kit and no difference. It wont idle and if the throttle is just off idle, it skips and sputters but will rev clean at full throttle.
What I have done so far, replaced the gas and cleaned the tank, replaced the fuel line and filter, disassembled the carb 4 times cleaning and rebuilding it, cleaned the air filter and changed the spark plug and none made any difference.
Offline bbroj
  • To be determined...
Re: any ideas for my atv
« Reply #1 on: July 08, 2011, 01:26:05 PM »
You could always sell it to SISF  :D
http://www.zggtr.org/index.php?topic=2390.0
COG 9331
Offline Wild_Bill
« Reply #2 on: July 08, 2011, 05:37:16 PM »
Still sounds like carbs need cleaning. I use gutiar strings to clean out the passages.
Might be coil breaking down. Check for cracks in the coil
Bill
Formerly known as Badnews_Bill
Offline JetJock
« Reply #3 on: July 11, 2011, 05:56:29 PM »
Water in the gas. We had the exact same problem and same symptoms on my daughter's boyfriend's Ninja. I checked everything else and a leaky gas cap was letting moisture in.
