Author Topic: Wanted.....Norm's lowering rocker  (Read 2945 times)
Offline bowtie39
« on: March 27, 2019, 04:33:05 PM »
Doing a shock mod and wanting to add this rocker.
Thanks so much
Re: Wanted.....Norm's lowering rocker
« Reply #1 on: March 27, 2019, 10:23:58 PM »
Don't have one, but I can get you Norm's phone number if you want?
Which shock are you installing. If a ZZR, may not need a rocker.
Offline bowtie39
« Reply #2 on: March 28, 2019, 12:01:44 PM »
Thanks but I've already contacted him.....I'm just too cheap to pull the trigger yet.  Not ZZR.  C14 shock
Offline jim snyder
« Reply #3 on: April 21, 2019, 08:55:26 AM »
I'm curious if the Soupys adjustable links would work with the C-14 shock.
« Reply #4 on: April 21, 2019, 09:27:13 PM »
they don't have the "bow" offset, to fit astride that shock.
Offline bowtie39
« Reply #5 on: April 21, 2019, 09:31:37 PM »
Thanks for noticing and comments!   :)
« Reply #6 on: April 21, 2019, 10:04:42 PM »
I think I recall a member that built offsets to push the links further from the rocker. (would allow the links to clear the shock spring)
I will try to find that posting, but I think the offset would significantly increase the amount of load on the bolt that passes thru the rocker.
Update; Found the discussion. May work, but he was using the ZZR1200 shock when he did the mod.
              http://forum.cog-online.org/tiressuspension-c10/yet-another-suspension-rebuild/msg652283/#msg652283
« Last Edit: April 22, 2019, 10:38:30 AM by connie_rider »
