Author Topic: Checking coolant level  (Read 8635 times)
Offline Silverbullet65
« on: February 16, 2019, 09:36:48 AM »
When looking through the fairing to check the coolant level
On a 2011 c14  should the bike be on the center stand? Or sidestand?
Does it matter?
Thoughts?
Safety is no accident
Re: Checking coolant level
« Reply #1 on: February 16, 2019, 10:31:08 AM »
The owner's manual says to position the bike so it is perpendicular to the ground. If you can do that at the same time as looking at the coolant level then do that. I have to put it on the center stand and put a board under the front tire when I do it without assistance in checking antifreeze level and oil sight glass level.
« Reply #2 on: February 16, 2019, 05:05:02 PM »
Thanks Marty
I used your method and I think it’s
On the full line. tough to
See ...really appreciate your help
