Author Topic: Are the C10 tires tubed?  (Read 2641 times)
Offline kzz1king
« on: July 06, 2011, 07:11:56 PM »
Stupid question, but are the c10 rims tubeless? Pulled my tires and they have tubes currently. Thanks
2010 CONCOURS
1974 Z-1
Offline Pfloydgad
Re: Are the C10 tires tubed?
« Reply #1 on: July 06, 2011, 07:15:12 PM »
Like any tire system, you can use tubes, but are not necessary. I am sure more will drop in, but it is probably a personal choice.
Ride safe all.
Greg
Offline Jet86
  • California
« Reply #2 on: July 06, 2011, 07:32:30 PM »
The bikes came from the factory with No tubes
Offline kzz1king
« Reply #3 on: July 06, 2011, 08:35:13 PM »
Thanks, I can't figure out why I put tubes in to start with. It must have came with tubes from previous owner and I followed suit I guess. I am going to go TUBELESS 8)
Wayne
2010 CONCOURS
1974 Z-1
Offline Summit670
« Reply #4 on: July 06, 2011, 08:58:00 PM »
You can buy the tubeless rim valve stems at the local auto parts store but remember these (my 87 anyhow) are the small dia type.
I ended up using the oem metal with new rubber from some stems I bought at the parts store.  I liked the OEM better than what I had bought so I just used the new rubber.
I did turn the rear 90 stem at a 45 degree angle but next time I'll leave it at a 90 angle to the rim because now every time I check pressure or add air I have to be careful the wheel doesn't turn on me from the pressure I apply to the valve stem.  The stem is still a 90 but I rotated it a little for better access.
Arctic Cat M8 163 rules
Offline Outback_Jon
« Reply #5 on: July 06, 2011, 09:59:19 PM »
If we're going to talk valve stems, I got the 85 degree stems from kurveygirl.  I point them both towards the right side of the bike for easy access when the bike's on the sidestand.
I just bought a second set for my recent tire replacement as a precaution against the seals getting old. (about 35k since I installed the stems)  But the ones I took off look quite good.  Cheap insurance, anyway.
Offline elvin315
  • Global Moderator
« Reply #6 on: July 06, 2011, 10:30:09 PM »
A few things have gone unmentioned. They don't seem to weigh much but a tube in a tubeless tire is unneccessary unsprung weight resulting in a rougher ride. Tubes in tubeless tires can overheat the tires. A warm tire grips better than a cold one (within the tire's operating temp range). A hot front  tire will get "greasy". Not literally but it will get slippery to the point of "washing out" resulting in a low-side crash. A tube adds thickness to a tubeless' supple sidewall and prevents the it from placing its tread on the road surface as designed.
Offline Pfloydgad
« Reply #7 on: July 07, 2011, 06:33:50 PM »
So there,
Ride safe anyway, even you Elvin, you smarty pants.
Greg
Offline kzz1king
« Reply #8 on: July 07, 2011, 07:11:52 PM »
For what it's worth the rear tube weighs 2.6 pounds (without air 8)).
It would have been fun trying to use my plug kit on a tubed tire!
2010 CONCOURS
1974 Z-1
