Author Topic: ### C-14 Shock Lowering Rocker / Links ###  (Read 2157 times)
Offline Motor32
  • '87 Concours '16 Ninja 300R
« on: April 19, 2018, 09:20:35 AM »
I want to swap the C-14 shock onto my '87 C-10. After reading the many posts about it, I was wondering where to purchase the correct lowering links or rockers to get the height back down to stock??? I still want to use the center stand, so from what I read some do interfere. Thanks for any help.
Offline Mettler1
Re: ### C-14 Shock Lowering Rocker / Links ###
« Reply #1 on: April 21, 2018, 08:24:53 AM »
   Might try here.
           http://forum.cog-online.org/index.php
               http://forum.cog-online.org/search2/
« Reply #2 on: April 22, 2018, 06:45:55 PM »
Norm Soucy makes a 1 1/2" lowering Rocket hat will work perfectly with your C-14 shock.
I used one when I did mine...
Look for it on the COG Forum, and do a search for Norm Soucy.
Here is 1 discussion. There are many about installing different shocks on a C-10.
http://forum.cog-online.org/tiressuspension-c10/twitchy-tires/msg616068/#msg616068
