Author Topic: coolant leak  (Read 1947 times)
Offline deuce72
  • 98 Concours
coolant leak
« on: May 05, 2017, 04:24:49 PM »
I've searched the threads and read most of the coolant and water pump issues. I may have a unique situation, or maybe not. I over heated about two weeks ago here in MN on a 34 degree morning. In less than 5 minutes coolant spewing. I replaced the thermostat with the 83 Honda Accord( I think) and everything seemed buttoned up. This morning coolant leaking from under the bike especially when warmed up. It appears to be from the water pump area. NOTHING from the weep hole. It appears to be more from just above the water pump. It is hard to see but I took a pic.
I did replace the seal last year and everything looked good with that install.
Any possible mistakes or misses? Any other possibilities??
Thanks!!
Deuce
98 Concours
Offline deuce72
  • 98 Concours
Re: coolant leak
« Reply #1 on: May 06, 2017, 11:02:44 AM »
No other suggestions? Looks like I'm buying a water pump and hope for the best!
98 Concours
