Author Topic: T-stat pipe leak  (Read 2116 times)
Offline SaturationDyes
T-stat pipe leak
« on: April 12, 2017, 02:41:07 PM »
Bumped my thermostat housing while removing my valve cover and caused a leak on the oring between the thermostat housing and the thermostat pipe. So order all new orings for the thermostat and for the thermstat pipe. But no my problem is i have a major coolant leak where the 2 thermostat pipes feed into the head. I still have the carbs in and would like to avoid removing them again. But i have now tried to get that to seal twice. Anyone have any tips on how to get it sealed. Second time i even tried a little bit of rtv(gasket high temp).
Thanks
Re: T-stat pipe leak
« Reply #1 on: April 12, 2017, 05:12:33 PM »
Sad to say it, but pull the carbs, and replace the o rings on the manifold pipe... don't waste time trying to do it with carbs in place, I've done them many times, and you have a 20% chance of success rate and will end up pulling the carbs in the end.. trust me on that...
Also forget the RTV and any other kluge shortcuts... it doesn't work, or hold, and makes a correct repair much more time consuming when it fails...
Murphs has the orings, might as well do the thing right... make sure to completely clean all the corroded goop off the pipe, and polish it with a scotchbrite pad till is shiney also, and paint it before installing...
If the front ones aren't showing signs of leakage(which they normally don't) leave them be until they need replacing.
When installing the manifold with new seals, lightly oil them, and make sure you polished out the recesses in the head that they push into...
Pay close attention to the rings while inserting, to push evenly, so they don't roll out of position. A small flat bladed screwdriver, of a shaved popcicle stick assists for pushing a ring into place while inserting the manifold, as the rings do like to "roll" out, pushing and assiting them to get into the bores is pretty much the best advice I can give, and as I said, it can't be done without the carbs off, because you can't see the ring roll out of position... then its all start from scratch again... when its leaking.
Also, once you replace all those rings, fill the bike and burp the system before putting the carbs back on, again, trust me that if you didn't get the rings installed correctly.... you will redo it all again...
« Reply #2 on: April 13, 2017, 06:05:47 PM »
Thanks man of blues. I put new o rings on the pipe but tried with the carbs on. And i will make sure to get a cleaner surface. With the carbs off can this be done with the valve cover on?
« Reply #3 on: April 14, 2017, 05:17:16 PM »
yes
« Reply #4 on: April 24, 2017, 01:21:37 PM »
Thabks again man of blues. Sure enough pulling the carbs was the trick. Was able to get a round wire brush inside the head and clean the ports for the pipe.
