Author Topic: Shift problems: front bevel gear case removal.  (Read 2838 times)
Offline cc_ryder
  • Jacksonville,FL ...................... Coggers ROK
« on: February 11, 2017, 02:33:02 PM »
I want to inspect the external shift mechanism but my manual does not show how to remove the front bevel gear case. I have removed everything but the connection to the drive shaft housing.  Does any know how to or have a manual that describes the procedure?
ROK
Retreads
Patriot Guard Riders   www.patriotguard.org
Offline jacksdad
Re: Shift problems: front bevel gear case removal.
« Reply #1 on: March 11, 2017, 03:26:52 PM »
any ideas? My bike has developed an oil leak from the bevel box area, oil is dripping onto the exhaust and smoking me alive!  :o
I can get all the oil seals locally, but should I be watching for anything else?
Offline cc_ryder
« Reply #2 on: March 12, 2017, 09:08:33 AM »
After further reading I find I will have to remove the final drive, swing arm and drive shaft to remove the front bevel gear case. If you have a leak from that case you will need a manual to replace any gaskets.
ROK
Retreads
Offline jacksdad
« Reply #3 on: March 12, 2017, 07:01:11 PM »
That's bad news 😥
Ive cleaned up the external area with degreaser and detergent plus hot water, the oil is leaking from the bevel box gasket. Can I replace this gasket and oil seals whilst doing the job, without stripping the drive train? I do hope so !😤
Offline cc_ryder
« Reply #4 on: April 15, 2017, 08:41:17 PM »
Sorry Jacksdad. You will have to remove all of the drive train to get the front bevel gearcase off. I just did mine last week. It takes a lot of work but it is not rocket science.
ROK
Retreads
