Author Topic: Couple Of Questions  (Read 2421 times)
Offline BigBrian27
Couple Of Questions
« on: January 27, 2017, 07:39:46 AM »
Got a new to me 1992 Concours.
It runs but needs some love.
The front brakes need help. I have purchased a master cylinder rebuild kit as it sticks sometimes. The rotors are grooved and need replacement. Is there an upgrade that I can do? Maybe upgrade to the 94+ setup?
There is an oil leak from the right side. Appears to be coming from the balancer and oil cooler. I have ordered the seals and gaskets. I am assuming this is commonplace on a bike with 77K. Water pump side seems ok.
Tires are worn and old. What are you guys running? I am thinking of going with the Shinko 777's.
I plan on doing a full tune up including filters, oil change, valve adjustment and spark plugs. Anything else you'd recommend?
With 77K should I replace the chain tensioner with a manual one?
I think that is all for now.
Thanks everyone.
-Brian
Offline Jim __
Offline qman
    • Autobahn Motors
Re: Couple Of Questions
« Reply #2 on: February 01, 2017, 12:50:55 PM »
Replace the spark plug connectors as well, they can be a problem. I have a manual chain tensioner on mine and it works great
Offline BigBrian27
« Reply #3 on: February 02, 2017, 06:15:56 AM »
Thanks for those links Jim.
What do you mean the spark plug connectors? The boot or the end that screws onto the coil?
Offline qman
    • Autobahn Motors
« Reply #4 on: February 02, 2017, 01:32:38 PM »
The boot that goes over the spark plug, they have a 5k ohm resistor, sometimes they get corroded and don't fire the plug properly
Offline BigBrian27
« Reply #5 on: February 02, 2017, 02:02:44 PM »
Good to know I'll add them to the list of parts to replace.
