Author Topic: ### Whiff of Antifreeze ###  (Read 4909 times)
Offline Motor32
  • '87 Concours '16 Ninja 300R
« on: May 24, 2016, 05:41:49 PM »
When I was out riding, when I would take off from a light I'm getting a whiff of antifreeze. After I got home I took off the fairings and let it run looking for any sign of a leak or drip. Nothing was found. This may drive me crazy. In the meantime I ordered new hoses from Murph's. Any ideas or suggestions are appreciated. Thanks in advance.
Offline Jim __
Re: ### Whiff of Antifreeze ###
« Reply #1 on: May 25, 2016, 05:27:51 AM »
Check the hoses associated with the overflow tank.  Also, check the level to make sure it's not overfilled.  While there, verify someone didn't use a screw that was too long to secure the belly pan and wound up puncturing or cracking the tank.  How does your radiator cap look?  Inspect the weep hole under the water pump.  It is very close to the exhaust pipe so if it's only leaking when running, the drip may be hitting the hot pipe.  Good luck.
« Last Edit: May 25, 2016, 06:01:15 AM by Jim __ »
Offline Deziner
  • Phoenix
« Reply #2 on: May 25, 2016, 06:40:58 AM »
It also could have been from a car near you
« Reply #3 on: May 25, 2016, 01:42:59 PM »
year and milage would help a bit, but I'll assume based on another thread you posted about forks, that its pre '94...
by this time, likely the large o ring sealing the 2 halves of the thermostat housing has turned to gooo... they all do...
and will produce this symptom. so will the coolant log o rings... and just about every other seal on the cooling system.
Offline Motor32
« Reply #4 on: May 25, 2016, 03:57:47 PM »
This is a '87. Today I cleaned / degreased everything. Checked all the hoses, the weep hole and every connection of the cooling system. Still nothing spotted. I'll have to keep and eye out until I get my new hoses on.
Offline Daytona_Mike
« Reply #5 on: May 25, 2016, 04:21:56 PM »
+1  :goodpost:
Offline Motor32
« Reply #6 on: May 25, 2016, 05:05:29 PM »
Thanks, I just ordered the thermostat and the log o-rings. Murph's saves the day again.
« Reply #7 on: May 25, 2016, 08:49:29 PM »
+1 Can't tell you how many times I've panicked over a smell that came from another vehicle.
Offline GKreamer
« Reply #8 on: June 21, 2016, 09:22:39 AM »
Were you able to replace the hoses and the t-stat/log o-rings?  I did that on my bike and, just like MOB said, the t-stat o-ring was just a mess like it had disintegrated.  If you have yet to, use fork oil to lube the o-rings.  I did that (thanks MOB) and when I finally got coolant back in the system I had no leaks (not counting the coolant that overflowed from pouring too fast :o).
Offline Motor32
« Reply #9 on: June 22, 2016, 03:05:15 PM »
Everything is on my bench waiting for a free day to get it done. Thanks for the tips.
