Author Topic: H4 bulb retainer  (Read 3019 times)
Offline nevadazx12
H4 bulb retainer
« on: May 11, 2016, 02:19:03 PM »
I am trying to add one of those LED bulbs to my Connie.  Cannot seem to get the retaining clip to attach, in fact I can't make it work at all, even without a bulb in there.  Any recommendations for a replacement clip??
gg
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
Offline cc_ryder
  • Jacksonville,FL ...................... Coggers ROK
Re: H4 bulb retainer
« Reply #1 on: February 11, 2017, 06:51:42 PM »
Have you checked to see if the clip is bent out of shape? If one side is bent it will not line up with the retaining ring.
ROK
Retreads
Patriot Guard Riders   www.patriotguard.org
Offline Rick Hall
  • Eruption
« Reply #2 on: February 12, 2017, 09:47:45 PM »
The hinge point is sloppy from the factory. I recall I crimped the sheet metal hinge knuckle with pliers 'many moons' ago. Easier, but still a PITA to retain a bulb replacement.
The wire bail is a medium spring steel. Unless you hork it up with a vice grip and pry bar, it should fit.
There is no replacement that I know of. But you might be able to bend something out of a heavy duty paper clip, *if* you have time, and *if* you have a ready supply of happy drugs.
Rick
Offline gbyoung
« Reply #3 on: September 04, 2017, 06:36:43 AM »
