Author Topic: C10 wheel interchange  (Read 2580 times)
Offline nevadazx12
« on: March 24, 2016, 05:52:26 PM »
Is there a list of wheels that will fit on an 86 connie from later models.  I am looking at a set from a 2001 model.
Most important, will the discs interchange too.
thanks
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
Re: C10 wheel interchange
« Reply #1 on: March 24, 2016, 06:41:12 PM »
Sorry that wheel does not work. Wheel bearing size is way different as well as disc size and spacing...
Offline nevadazx12
« Reply #2 on: March 24, 2016, 10:59:11 PM »
thanks Tony,
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
Offline RFH87_Connie
« Reply #3 on: March 25, 2016, 06:10:17 AM »
You can use anything up to a '93 I believe - without severe modifications and additional parts.  The rear I think would be all years.
« Reply #4 on: March 25, 2016, 07:19:59 AM »
That is correct the rear from all years C10 would/will fit without issue as will many other rear wheels as Kawasaki used the same wheel spline and axle size for quite some time. Only cravat would be the bolt pattern and location from CL of the brake disc mounting boss. While much too wide even the new Concours C14 rear wheel has the same size bearing and drive spline....
As to the front the 86 to 93 used the same wheel and from 94 on it was different... The below listed bikes all least used the same wheel bearings so you can look through them for possible candidates to being grafted in the old forks.
86-92 KX250
78-79 KZ400B
86-93 KX500
87-01 KLR
77-79 KZ650B
77-79 KZ650C
1980 KZ750 G LTD
91-92 ZR750
76-77KZ900
79-80 KZ1000 E Shaft
78-80 KZ1000D Z1R
73-75 900Z1
86-93 ZX500
90-93ZX600D ZX6
77-80KZ1000 A B G
78-80 KZ D,E,F
76-79 KZ 750B
95-96 Zx1100 GPz
92-94 ZR1100
